disc brake swap
Old Apr 11, 2017 | 11:42 AM
1968f100lover's Avatar
1968f100lover
disc brake swap
I'm fairly new to owning an F100. Bought a '68 SWB a couple of years ago. It has all drum brakes. A friend has an '80 and '84 with front disc brakes that he is willing to give me the front disc brake/I beams if I can use them. Can this disc brake/ I beams swap be done? Thanks in advance for any info.
Old Apr 11, 2017 | 12:09 PM
TeachNlive4ever's Avatar
TeachNlive4ever
No sir, that year is not interchangeable. 73-79 are your donor years.
I don't know your location but there is a guy in Arkansas that often posts on Craigslist the disc brake conversion you seek.
Old Apr 11, 2017 | 02:02 PM
1968f100lover
thanks for the info...I'm in Ellis co. Texas. South of Dallas
Old Apr 11, 2017 | 02:32 PM
HIO Silver's Avatar
HIO Silver
Ya might wanna pick up that 80 rear axle if it has a small lug pattern. It would make good trading fodder for someone doing CV subframe retrofit.
Old Apr 11, 2017 | 02:42 PM
TeachNlive4ever
Hmmm, HIO makes a good point on scavenging. If he's still has the rear end, find out what gear ratio it has.
I'm in Dallas by the way.
Old Apr 11, 2017 | 05:24 PM
1968f100lover
thanks for the info. He's not ready to scrap it just yet. I'll ask about the ratio.....it's still got the 300 inch six in it. It does have the 5 X 5.5" bolt pattern
Old Apr 12, 2017 | 11:26 AM
ultraranger's Avatar
ultraranger
If the (9-inch) rear end in the truck is behind a six cylinder, good chance the ratio will be a 3.50 or a 3.70:1 ratio.
My '69 F100 with a 240 and a C4 came with 3.50 gears (28-spline single track differential/28-spline axles) I swapped to 31-spline axles and a 31-spline Traction-Lok differential with 3.50 gears.
Old Apr 12, 2017 | 11:29 AM
TeachNlive4ever
THAT is what I'm interested in.
Old Apr 12, 2017 | 11:12 PM
spdcat72's Avatar
spdcat72
If you search Craigslist under auto parts general, and search F100, you'll see his adds. He's actually on the Texas side of Texarkana, not far off I-30. He parts out dent trucks, and usually has a disc brake front end. I think I paid him $225 for complete front. Maybe a bit high, but he pulled it, and I didn't have to. He's a nice fellow.
Old Apr 13, 2017 | 07:05 AM
ultraranger
If it's the person who I think it is, he lists the take-off parts for $250.00. This is as-is, non-clean parts. You also have to consider that this is a complete assembly you're paying for that most likely has rotors that are trashed, calipers that will need to be rebuilt or traded in as cores, brake hoses that will be no good, wheel bearings and seals that will have to be replaced, kingpins/bushings, I-beam bushings and radius arm bushings and brake pads that will need to be replaced. --point being, you would be buying a lot of parts that will be of no use plus, its added dead weight that you'll be paying shipping costs on.
If you're going to convert to front discs and installing the donor front suspension too, all you need are the beams, radius arms, spindles, dust shields and you could get the calipers as cores. The rest should be considered trashed parts that should be replaced with new parts.
I've done this swap twice now --on my own '69 F100 and on a friend's '72 F100.
bryanA73
Aug 13, 2018 09:49 AM
BCHauler
1997 - 2003 F150
May 4, 2013 10:56 PM
rangergirl94
Dec 12, 2012 09:03 AM
74ford4x4
Jan 19, 2011 12:52 PM
stealth1
Mar 19, 2008 10:42 PM
