Track bar
Old Apr 10, 2017 | 10:31 PM
xaviar's Avatar
xaviar
Track bar
Hi all,
I'm in the process of gathering most front suspension pieces to rebuild my front end.
Need some advice about replacing the factory track bar? Is this something I should upgrade? There are many different ones. But, I've narrowed it down to either a fab tech or carli. That is if this is something I should upgrade.
Carli Adjustable Track Bar 2005-16 Ford F250/F350 4x4 CS-FATB-05
https://www.realtruck.com/fabtech-ad...006Y743MA.html
Thx
Old Apr 11, 2017 | 09:40 PM
xaviar's Avatar
xaviar
No one has replaced their track bar? Or know if there is a better one than our stock one?????
Old Apr 11, 2017 | 09:52 PM
tfunk88's Avatar
tfunk88
Are they upgrades? Most likely. Are they necessary? Depends. Is your truck lifted or leveled? If so then I'd say yes.
Old Apr 12, 2017 | 09:23 AM
Carolina Rig's Avatar
Carolina Rig
Originally Posted by xaviar
Hi all,
Thx
Of those two track bars, I'd go with the Fabtech. Looks like it can be adjusted without removing it.
I installed a BD adjustable track bar on my truck and it's been fine.
If you're lifted or leveled, I think the adjustable track bars are worth considering. If you're at stock ride height, a bushing replacement to the original leaves most people happy.
hope this helps
Old Apr 12, 2017 | 08:46 PM
xaviar's Avatar
xaviar
Yep. Fab tech is the one I'd pick also. I'm just at stock ride height but considered an upgrade if there was better.
Mine looks fine but since I'll be under the truck anyway. I was going to replace it.
Looks like the bolt securing that bushing is torqued to 410 ft/lbs
Old Apr 13, 2017 | 06:17 AM
Carolina Rig
Actually, I looked at it's only 406. hahaha
I slide a 4-foot cheater bar over my large breaker bar, give it a couple good tugs and call it good.
Old Apr 16, 2017 | 04:27 AM
Yahiko's Avatar
Yahiko
If your not doing a lift I would just keep the OEM track bar.
The one thing to do is check the bushing on the drivers side.
I had to replace mine and I went with one from Energy Suspension >>>energysuspension.com | Welcome
I also replaced the track bar ball joint do to it being loose.
Also if your doing the work yourself when the bar is out don't
let the axle move. You will play hell getting it back into alignment .
Old Apr 16, 2017 | 07:43 AM
xaviar's Avatar
xaviar
Thanks for the link and tip. I would have not known that piece of info.
I'm not lifting the truck. So, I'll keep the OEM one.
Old Apr 16, 2017 | 12:26 PM
Yahiko's Avatar
Yahiko
The way that they tested mine when I was there so I could see too.
They started the engine and looked at both ends of the bar while they
rocked the wheel. The bushing had more wobble than it should by a
large amount as did the track bar ball joint. After replacing both ends
it sure drove a lot better.
bert cook
May 17, 2013 05:36 AM
Oxfordrider
Feb 24, 2013 08:29 AM
LWW
Jun 4, 2012 12:26 PM
SpokaneJim
Apr 28, 2010 09:31 AM
Mr. N
Jul 7, 2008 05:22 PM
