More IFS questions
Old Jul 5, 2008 | 05:17 PM
Mr. N's Avatar
Mr. N
More IFS questions
Hi all
I have a '53 f100 with a volare up front and a 9" in the rear. I bought it this way and am really unhappy with this set up. The tortion bars are cracked up pretty high giving the truck a stance that is only slightly lower than stock. However the ride is still way too soft in the front. I have replaced the front shock and that helped some but the truck still leans terribly around corners.
I am thinking of scrapping the volare and trying something else. Before I stick a bunch of money into something I figured I'd check with those of you that are driving your trucks and actually like the ride quallity.
1. I'm cheap and don't have a huge budget for my truck.
2. The truck will hopefully be a daily driver for me not a show truck
3. I'm NOT looking for something that drives like a lincoln. A sportier ride would be more what I'm looking for.
With that said, any suggession?
I don't have the $$$$ for a mustang II kit.
I'm kinda leaning towards the dodge dakota front end. Is anyone currently riding on one? What do you think?
Thanks
Old Jul 5, 2008 | 05:30 PM
mechmagcn's Avatar
mechmagcn
Because of the amount of frame removed to install the Volare IFS, removal is not an easy task. It can be done, jnolion has done it and did a good write-up on the process. Could the addition of some sway bars front and rear help the ride and leaning problem. I would try this before I tried to remove it. I don't know what sway bar will work on the front, but a bar from a 88 BroncoII is almost a direct bolt-in with a 9" rear-end.
Old Jul 5, 2008 | 07:04 PM
sdetweil's Avatar
sdetweil
the Volare already has a sway bar built in..
Sam
Old Jul 6, 2008 | 05:24 AM
49willard's Avatar
49willard
The way to reduce body roll in a corner is a larger sway bar. I would investigate aftermarket bars for the Volare first.
Before I started on my truck I drove a very nice 56 with the Volare IFS. I also found it to be softer than I wanted and based on that I decided to go the Jaguar route. Since my truck continues to be a work in process I can't provide any personal feedback on the Jag setup. Holmsey from across the pond did a 55 with Jag both front and rear which hit the road recently. I know that he has been happy with the handling. Holmsey is running a stock Jag sway bar, 3/4" in front. That is what I currently own however I plan to drive the truck first with the standard bar and if I experience more body lean than I want I will upsize the bar with one of the aftermarket ones (readily available up to 1" diameter). There are a number of members on the forum running the Volare IFS who can help you more with specifics.
It all comes down to personal preferences.
Old Jul 6, 2008 | 07:14 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Some of that lean may be coming from the rear. I have a Volare in my 48 and a rear anti-sway bar and mine doesn't lean at all...
Old Jul 6, 2008 | 07:19 AM
sdetweil's Avatar
sdetweil
I can't wait to get mine out on the road.. it has a 1-1/8th bar in front, and I just added a 7/8 hollow bar bar in the back. The rear bar has already tightened up the whole vehicle just sitting in the garage.
but 1-1/8th is as big a front bar as I have seen referenced or listed anywhere. I did replace all the bushings with polyurethane (from energy suspensions) when I rebuilt the front end..
Sam
Old Jul 6, 2008 | 10:18 AM
8bahead's Avatar
8bahead
Mr.N I have a volare clip in my 53 I used the 6 cylinder one, if you can find a Dodge diplomat big sedan or there was also a chrysler that used the same k member I cant remember the name of it. It has 1 1/16 " diameter sway bar mine came off of and cop car! The one you have is half that size. I have no issues with roll, good luck.
Bob
Old Jul 6, 2008 | 11:17 AM
Mr. N's Avatar
Mr. N
I do have a second bare frame that I was going to use. Like you said removing the volare would be a big job. Does anyone have info on aftermarket companies that sell swaybars for the volare?
Thanks
Old Jul 6, 2008 | 11:20 AM
Gary E's Avatar
Gary E
I would echo what others have said above, If its a sway issue that can be resolved. I would consider urethane bushings, a rear bar and/or a new aftermarket bar like Sam suggested. I do not have mine on the road yet it came out of a v8 car with 15/16ths bar and I kept the rear anti sway bar from the donor car. Hopeing it handles decent and gives a comfortable ride when I get to drive it someday
These guys have pic of one racing
Firmfeel Mopar Suspension and Steering
Old Jul 6, 2008 | 11:24 AM
LEckart's Avatar
LEckart
Try doing a "google" on Volare sway bar. You should get alot of information.
Old Jul 6, 2008 | 11:31 AM
Gary E's Avatar
Gary E
Performance Suspension Technology - DODGE - PLYMOUTH Aspen,Diplomat,Gran Fury,Mirada,Volare 1976-89
Don't know what supplier Sam used but I found that one on a search.
Old Jul 7, 2008 | 09:19 AM
Okiedokie's Avatar
Okiedokie
I have a Volare in my 53. I have no idea what sway bar size is, but it came from a V8 car. It rides very well, I also replaced all worn parts and have KYB Gas Adjust shocks. I have no complaints on cornering, I do have a real sway bar also. I am running five leaves on the rear and it can be a litle choppy at times. Any load in the bed helps that so I may soon remove one more leaf, although that will probably take away any load carrying ability. If I were starting over I would go with a four bar with air bags, or maybe one of the air over leaf set ups. All shortcomings aside, I just love looking down that hood. It does not ride or handle as good as my 2000 F150 or my wifes Highlander, and the A/C is not as good, but boy it sure is more fun. The best part of the deal is after I park it when I go in somewhere, I get to walk back to it knowing it's mine, no amount of "better appliance" can come close to equaling that feeling. I have no regrets about the Volare other than maybe appearance under the hood and access under front of motor.
Old Jul 7, 2008 | 12:05 PM
CharlieLed's Avatar
CharlieLed
Mr N ... there are thousands of F100 trucks on the road today with Volare IFS, if yours is not functioning well then the problem lies with the condition/setup and not with the Volare design. I have seen some installations where, for some unknown reason, the sway bar was missing...if yours is not a 1-1/8 bar or if it is missing then that would be the first place to start. Bad bushings is the root of many front end issues, if yours are dry and/or cracked then it's time to replace. I think that if you spend some time and just a little cash on your present setup that you will see a significant improvement in the ride and handling. These old trucks are so top-heavy that I don't think that you will ever get a "sporty" ride, but with lowered spindles and stiffer sway bars you may get closer.
Old Jul 7, 2008 | 04:21 PM
Jag Red 54's Avatar
Jag Red 54
Lets spend the least amount of money necessary to fix the problem. If the bushings are in good shape you need to:
Step one: Add afore mentioned gas shocks front and rear.
Step two: Add afore mentioned after-market sway bars front and rear.
Total cost? I would estimate $600 and you'll be styling
Last resort is to execute the reverse Niolin manuver! Jag
Old Jul 7, 2008 | 05:22 PM
raerjim's Avatar
raerjim
Try these folks. bobsf100.com. Bob's the man concerning Volare clips. (or so i'm told)
fatfenders
86
Feb 26, 2013 07:48 PM
Greg55_99
Apr 14, 2009 04:36 PM
Doraville
Jun 6, 2008 06:17 AM
Jerico
17
Sep 18, 2006 11:33 PM
theGman
21
May 7, 2004 07:31 AM
