Motor Mounts
Old Sep 1, 2003 | 06:06 PM
Wheels6293's Avatar
Wheels6293
Motor Mounts
Good day folks!
I'm helping passpurp64 and we're trying to figure out what to do with these engine mounts. '64 f-100 w/223. As ya'll probably know, the 223 in this truck is mounted in the front and back. I don't see any bolt holes to put frame mounts on the sides of the engine. Do you guys know of any kit or suitable substitute?
Can the 300 be mounted the same as the 223?
Also, in order to find a bellhousing, we must know what kind of tranny is in the truck. It's a manual 3 speed. Do you guys know where to look to find an ID tag or a stamp? How bout a website with a list? We found a number inside the bellhousing, but not sure where to look.
Thanks, you guys rock!
Old Sep 2, 2003 | 01:40 PM
Rosati's Avatar
Rosati
Motor Mounts
Your tranny is most likely a standard Light duty Ford 3-speed and should be scrapped if you plan on any performance or towing.
Check here for the mounts info.
https://www.ford-trucks.com/forums/s...=%25252Bmounts
sgtcoyote
Jun 22, 2013 11:25 PM
fordmanforlife246
16
Mar 5, 2011 02:29 AM
kooper909
22
Sep 1, 2006 09:21 AM
Customcab
May 30, 2005 10:15 PM
