Six cylinder engine mounts.
Old May 24, 2005 | 09:47 AM
Customcab's Avatar
Customcab
I posted in the classifieds in need of engine mounts for installing a 300 into my 59 F100, (Originially suppose to have a 223cid eng)currently have a 64 292 cid in truck; seems that the preproduction companies only sell the pads & bushing type items; also didn't find any at the Supernationals vendors.
So if you got any for sale let me know.
Thanks;
Mitch
Old May 24, 2005 | 07:00 PM
Madathlon's Avatar
Madathlon
Do you need the rubber mount parts or the steel mount brackets? and is the for front and rear ?
Old May 25, 2005 | 04:19 AM
Col Flashman's Avatar
Col Flashman
Madathlon
300 I-6's have Center Engine Mounts, not Front & Rears as the 223's do.
Custom Cab
Contact me via P.M. for the Mounts you need.
Old May 27, 2005 | 04:57 PM
Customcab's Avatar
Customcab
I'm looking for if possible the mounts/ brackets; I can purschase the insulator (Bushing) through after market companies; but finding the brackets for the front two sides and rear engine mount is challenging. I have the 8 cylinder mounts in the truck attach to a 1964 292cid engine, Im wanting this next winter to install a 1975 300cid 6 cylinder. I'm hoping thru this forum I will come across someone who's trying to upgarde to a v-8 from a 6 cylinder and are willing to sell or trade engine mounts.
I don't know if a 300 wont mount into a 59's frame; looks to me that I have two bolt holes on the front side of the engine block right behind the Harmonic balance / crank wheel location.
Old May 28, 2005 | 02:37 PM
Col Flashman
C.C.
I am currently in the process of installing a 300 I-6 & have already attempted or am attempting to take advantage of all options available to secure it into the Olde Girl.
Those front bolt holes are only for the Brackets that suppoert the Alt, P/S, A/C, etc. & so far have not proved deep enough to be used as Engine Mount Supports.
As I Stated previously, contact me via P.M. as I've the Complete Engine Mount Brackets for the 300 I-6 you are Looking for!
Old May 30, 2005 | 11:11 AM
Customcab's Avatar
Customcab
Thanks Colonel;
I'll P.M. ya.
Mitch
Old May 30, 2005 | 11:22 AM
Customcab's Avatar
Customcab
Hey Colonel;
I'm currently not smart enough to p.m. you; So I'll state my problems here;
I have the mounting brackets and pads from when I pulled the 300 out of my 65 F100; Iv'e seen a 64 with V-8 brackets welded into the side's of the frame; I was hoping to beable to find bracket to front mount my 300 into my 59F100. But I understand more clearly now; once you stated the front holes are for alt & p.s. etc.
Thanks for your patience & expertise.
Mitch
Old May 30, 2005 | 01:03 PM
51dueller's Avatar
51dueller
You'd probally want a front mount like this.
Old May 30, 2005 | 09:13 PM
Customcab's Avatar
Customcab
dueller;
Seems the reproduction co's have only the bushing and bolts. Not the actual mounting bracket.
I would like to beable to install the six cylinder mount onto a 75 300cid engine; was told thats a no-go. I do have the orginial brackets from when I pulled the engine out of a 66 donor.
I assume there's a rear mount also; I have a v-8 mount currently in the truck; but would like to install a 300 for torque & towing with a 4speed.
Customcab
Old May 30, 2005 | 10:15 PM
51dueller's Avatar
51dueller
If you use the front mount for the 300 like pictured above you will need to find a bellhousing with the rear mounts. I know the 65-66 F-350 trucks have the required mounts you need. They still used the 64 style frame.
FordF350Superduty
73
May 17, 2017 10:52 PM
MISTERBIGED
Jun 13, 2014 09:59 PM
cletusclark
Apr 8, 2012 05:07 PM
CamperSpecialMike
Sep 19, 2010 08:59 PM
Scott_McGee16
Jul 22, 2004 09:12 AM
