Towing capacity
Old Apr 10, 2017 | 02:09 AM
Frank771's Avatar
Frank771
Towing capacity
Hello there folks I'm curious if you could help me out and decode this vin I have a 4000 pound trailer Im hoping to tow can you let me know what my max is and if the tranny is good enough to tow and all that stuff thank you so much.
Old Apr 10, 2017 | 03:30 PM
Slowpoke Slim's Avatar
Slowpoke Slim
What is the truck's scaled weight without the trailer?
Old Apr 10, 2017 | 05:40 PM
Frank771's Avatar
Frank771
it is 2400 pounds
Old Apr 10, 2017 | 09:12 PM
Slowpoke Slim
I don't see how that's possible. Your truck weighs 2400 lbs?
Old Apr 10, 2017 | 09:27 PM
Frank771's Avatar
Frank771
Oops sorry 4600
Old Apr 10, 2017 | 10:37 PM
Conanski's Avatar
Conanski
That is a '93 or '94 pickup so tow rating is based on the powertrain combo(engine, trans, axle ratio), and the ratings themselves can be found in the owners manual. Looking at the certification decal I can see it has the E4OD trans and a 3.55LS axle but I'd have to decode the VIN to get the engine. That isn't necessary though as even with the 4.9 this truck has a 10000lb GCWR which means you could tow a trailer weighing up to about 5000lbs and that goes even higher with the two V8s that were available. So yes you can do it but a trailer brake controller is manditory as this trucks brakes are marginal at best.
Old Apr 10, 2017 | 11:19 PM
RA12726's Avatar
RA12726
Banned
Also... if it still has "P" tires (rather than LT) I would be careful. Passenger car tires can get squirrely towing.
Rob
Old Apr 12, 2017 | 02:53 AM
mrollings53's Avatar
mrollings53
I agree that a truck should have LT tires, but if it was rated for passenger tires stock there shouldn't be a problem towing within the limits set by Ford while following the tire pressures on the placard.
Old Apr 12, 2017 | 07:47 AM
wrvond's Avatar
wrvond
Certainly not a problem or a show stopper. But P-metric tires are not going to feel as solid as D or E rated LT tires.
I'd say it's more a matter of confidence than anything else.
Old Apr 14, 2017 | 12:08 PM
crewzer's Avatar
crewzer
Lightbulb
They're "P" tires, but the cert label indicates the OEM tires were "XL" (extra load) type and construction. At 41 psi max load inflation, they're good for 2,183 lbs. each, or 4,366 lbs. for both. The rear axle GAWR is but 3,776 lbs., so the OEM-spec tires should be good to go.
I had the same size/spec tires on my '86 Suburban many years ago, and I had no problem towing loads within GM's guidelines.
HTH,
Jim / crewzer
wyollie
All Things Towing
Dec 24, 2018 08:51 AM
RedRaiderFan
All Things Towing
Sep 13, 2015 09:18 PM
walbert52
Jan 31, 2011 10:39 AM
aquaholic
All Things Towing
22
Mar 21, 2007 05:29 PM
Eyerock
All Things Towing
Jan 20, 2004 04:42 PM
