Lifters
Old Apr 9, 2017 | 10:12 PM
akblackfoot's Avatar
akblackfoot
Lifters
Been hearing more and more about lifter failures in the 6.0 (probably since I've proactively tried to prevent all the other failure points :-) ). Just wondering how common it actually is and what I can do to prevent it. Are most of the failures due to poor maintenance or is this another failure point of the 6.0 because of design?
Old Apr 10, 2017 | 01:58 PM
Benchwrench's Avatar
Benchwrench
As I see it, there's nothing wrong with the design. Those lifter failure cases are from the implementation of using the wrong spec'd. component.
The stock 6.0 OEM pushrods that are originally installed are too tall which causes the hydraulic lifters to exert excessive preload pressure on their roller bearings, compounded by actuating two valves per lifter.
This is why I think it's important to install OE 6.4 pushrods at HG R&R, these happen to be .047 shorter than 6.0 OEM pushrods. Especially after the heads are decked, as head decking contributes increased hydraulic pressure on the already stressed pre-loaded lifters, contributing that much more pressure on their needle bearings. Some have claimed the newer/shorter pushrod update doesn't matter since the lifter will automatically adjust up the lash. Some say the OEM 6.0 pushrods were too long to begin with regardless of lash pressure. At any rate, each lifter is expected to support two sets of valve springs. (16 lifters supporting 32 valves) On a diesel engine.
Currently, the 6.0 and 6.4 pushrods have the same Ford part number because of this discrepancy.
Don't know if it ever made it to become an official Ford "TSB" this late in the game.
Old Apr 10, 2017 | 05:14 PM
ToolmakerRob's Avatar
ToolmakerRob
Is this something that should be changed as a preventative maintenance item if doing any type of work where the motor is apart, ie head gaskets?
Rob
Old Apr 10, 2017 | 05:31 PM
Benchwrench
absolutely,
8C3Z-6565-B is the new part number, an R&R update.
Old Apr 10, 2017 | 05:39 PM
diesel_dan's Avatar
diesel_dan
So any correlation to stock failures versus decked head w/ original pushrod, failures? Or are they failing pretty much equally...
Old Apr 10, 2017 | 05:45 PM
Benchwrench
I don't know. A long standing 6.0 shop would have the skinny on that.
I do know that once my 6.0L lifters fail, it's pretty much game over.
granted, this is should be considered "normal wear" for a half-mega mile duty cycle.
If you don't get a chance to watch this whole video, just view it from 6:47 -7:12 (for a more detailed, technical explanation).
Old Apr 10, 2017 | 06:47 PM
akblackfoot
So you can't replace the rear lifters when doing a head gasket job without pulling the rear cover? How much labor does that add if the engine is pulled anyway?
Old Apr 10, 2017 | 08:32 PM
TooManyToys.'s Avatar
TooManyToys.
I can't read this thread ......
Old Apr 10, 2017 | 08:49 PM
2006powerstroke90's Avatar
2006powerstroke90
why not? Lol
my last 6.0 had a lifter fail at about 265,000 miles..I didn't own it at that point thank god
Old Apr 11, 2017 | 12:37 PM
Benchwrench
the above Labor scenario would be only for an isolated case of a failed lifter.
How much labor does it add, you ask? All of it!
Old Apr 11, 2017 | 01:25 PM
akblackfoot
I guess I'm missing something. If the engine is pulled to do headgaskets, heads are off. You can easily replace the front lifters correct? But the rear lifters involve more disassembly. I'm asking how much and how many hours labor basically just to do the lifters beyond what's involved for the heads. No failure, just replace them as a wear item.
Old Apr 11, 2017 | 02:47 PM
Benchwrench
I wouldn't think a guy would be charged any "hours" added to a HG job if you want to replace the lifters. You're just not going to be able to all of them.
Otherwise, they're right there and easily accessible. Just pay for the new parts. Shop time for HG job is big enough and the 10 minutes it takes to change them out isn't going to make or break the job.
Besides, a good shop should automatically pull the "accessible" lifters and give them a once over just in case there is a problem.
If you ask for new ones, I'm sure they'd sell you new parts. Personally, I would let 'em ride if there's nothing wrong with them.
Old Apr 11, 2017 | 02:59 PM
Yahiko's Avatar
Yahiko
You can't get at the back lifters with the branch tube in place.
To remove the branch tube you have to pull the rear cover.
That said we have a shop in town that is rated very good. His policy
is that if he is at a point where the rear cover is exposed and the heads
are off he will do lifters if the engine has more than 200K on it.
I think if I were down to the point where I had the heads off and
the trans out I would pull the rear cover and replace the lifters
and add a new style set of push rods.
The only thing I question is new lifters on a used cam. It used to be
that you worked very hard to get each lifter back where it came from
do to wear patterns on the cam and lifter. But that was back in time
when we did not have the roller cams and lifters in use.
Old Apr 11, 2017 | 04:30 PM
jsm180's Avatar
jsm180
I see corrosion pitting on Anthony's lifters and I would imagine the inside looks the same and would destroy the needles.
I would be very surprised if Bill's engine stayed together for 6 months if he didn't pull it all the way down and clean the metal out. Hard to believe he left that video up, it's hardcore shade tree.
Old Apr 11, 2017 | 04:43 PM
Benchwrench
I noticed that too, as he's getting some hours in that engine.
I was supposing he was just playing with it for videos sake.
There comes a time when you just have to fold, and IMHO this is one of them, I see just a core, but then again I see his point that the screen caught the debris.
I'd throw in the towel on this one, especially at 203k mi. as it's a complete overhaul at this point.
