Heater Valve Control Cable
Old Apr 9, 2017 | 09:14 PM
JefflovesF250s's Avatar
JefflovesF250s
All: Heater valve control cable #18518 on the diagram shows a "foam rubber" collar at the location where it goes thru the firewall.
Mine is missing and there is no separate p/n for the collar.
Has anyone any ideas on what to use to seal/cushion the cable where it goes thru the firewall? And if so what are the dimensions?
Thanks in advance. Jeff
PS I have a '66 F250 with the "deluxe heater"
Old Apr 9, 2017 | 10:21 PM
john jamieson's Avatar
john jamieson
Some of the parts places sell rubber grommets to plug holes in the firewalls and other places. You could buy one to plug the hole and then drill a hole through it for the cable.
Old Apr 10, 2017 | 09:35 AM
JefflovesF250s
Thanks John. The exploded view diagram shows a foam rubber collar, so I would like to look for that option first.
I do have rubber grommets, and could use your suggestion, but want to try to get as original as I can before using this option.
Jeff
Old Apr 10, 2017 | 09:57 AM
TA455HO's Avatar
TA455HO
Lead Gopher
You must be referring to the foam rubber section here.
Chad
Old Apr 10, 2017 | 10:04 AM
JefflovesF250s
Chad: Yes, any ideas/p/n on a replacement, that I would have to slip over the end? Jeff
Old Apr 10, 2017 | 10:14 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Like you say, it is part of C5TZ-18518-A so there is no separate part number for the foam piece.
NOS Parts Source shows 1 cable - I have not checked if it has the foam piece or not, but they want $150 for the cable shipped ($140 plus $10 for shipping).
Bob Allen also has one cable showing in stock. I've never called them to inquire about a price for theirs.
Chad
Old Apr 10, 2017 | 11:12 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
NOS Parts Source shows 1 cable (no longer listed).
Bob Allen also has one cable showing in stock (website on PV last updated 2/04/2016).
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746 (PV).
RED TAYLOR FORD in Corning AR has 2 = 870-857-3518 (D2D).
Allen lists parts on three websites: PartsVoice.com, rearcounter.com and the D2D (Ford dealer parts locator). Only PV shows the cable, so it's probably gone.
Old Apr 10, 2017 | 11:29 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Short of buying a complete cable - if all you need is the foam piece - I'd be happy to take some measurements of it for you if it would help at all. Seems like a fairly simple item.
Chad
Old Apr 10, 2017 | 11:47 AM
JefflovesF250s
Chad: Yes measurements would be very helpful, OD, ID, Length, if possible.
I can locate stock that will allow me to cut-to-size a replacement.
Thx. Jeff
Old Apr 10, 2017 | 12:00 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I thought you might say that.
OD - 1"
ID - 1/4"
Length - 2 1/4"
If you make one maybe you can do a few others for no additional cost if they only sell the stuff in longer lengths.
A subtle detail on this one is it has a ridge on opposing sides. You can see the one ridge in this photo and there is another ridge on the lower side not seen from this angle. Just something about the mold they used probably.
Chad
Old Apr 10, 2017 | 12:10 PM
Crazyhorse power's Avatar
Crazyhorse power
Were does it come through firewall At ? I cant seem to find where hole is on my 66 F250? The cable was just wrapped up under dash, but had a valve in heater hose?
Old Apr 10, 2017 | 12:21 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Wow, you signed up 12 years ago and this is your first post? I'd say welcome aboard, but you should be saying that to me....lol.
Quick question and I'll grab you a picture of that if someone else doesn't beat me to it. Is your F250 a 2WD truck? I could take a pic of the 4WD - it's in essentially the same spot - but to make it specific to your situation.
I'd probably take one of the 2WD since it was the most common, but either way.
Thanks,
Chad
Old Apr 10, 2017 | 12:59 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Here's a web site with the correct inside/outside dimensions if you could get it in black instead of tan.
Foam Tubing, 1 OD 1/4 ID x 1 ft (6)
Chad
Old Apr 10, 2017 | 01:18 PM
Tedster9's Avatar
Tedster9
I'm impressed he remembered his password. Pro-Tip: writing it down on a scrap of paper is not a good plan.
Old Apr 10, 2017 | 01:34 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Opening is just below the cowl lip - to the left of the wiper motor mounting area and to the right of the raised area for the heater plenum, as seen from the engine compartment side. This is my 2WD truck.
Chad
