truck stalls out and cranks hard for 7-10 seconds before starting if I don't let it warm up adequately before I start driving. Transmission is hesitant to shift. Also, white smoke comes out exhaust if it's cold and I get in the throttle too much or if I hit 70+mph. Thoughts on issues?
Could be the glow plug relay is dead. Next cold start hold a big screwdriver across the big terminals on the GPR. That will energize the GPs. And give you a nice zap if you're not careful. Hold for 30 seconds before starting. Should make a big difference if that is the problem.
