Adding Adaptive Cruise Control - Complete!
Old Apr 9, 2017 | 02:27 PM
Ecoboost_Morgan's Avatar
Ecoboost_Morgan
Hi Everyone. I am new to this forum, not new to this industry. I have an ongoing thread on another board, but thought I would share on this platform as well.
I have a 2016 F150 502a, this will not work on XLT systems due to the harness behind the dash and IPC screen. Perform this mod at your own risk. The parts list and required FORScan changes are posted below. Enjoy!!!
BATTERY - Disconnect it.
HUD - Easy to remove the blank plate and add in the HUD module. Two retaining clips on either end with the HUD wire connected to the blank. Remove the plate with a small screw driver or trim removal tool - pops right out. Straight forward to install new trim plate and the HUD module. Easiest part of the install!
WIRING HARNESS - The new harness powers fogs and the new CCM module. The connector you can see from the top by the passenger headlight assembly. It lays horizontal in a small triangular space. Getting it out was a challenge until I removed the bumper. Three bolts on either side and the bumper is off and the harness is right there. Knowing what I know now I might be able to get the harness out without pulling the bumper, but only because I've done it one time.
SENSOR MODULE - The new bracket goes in very easy. Level the new sensor and you're good to go using the top alignment screw and a reverse torx socket. Three plastic retainers in the bumper itself; two screws in the top of the bracket to the metal frame behind it.
STEERING WHEEL CONTROLS - Make sure the battery is disconnected and that there were no airbag faults prior to disconnecting the battery. Always keep away from the face of the airbag and handle the unit VERY carefully. If dropped, do not reinstall the airbag. Getting the airbag out with two hex wrenches was easy. You can lift it right out and sit it on top of the wheel assembly. Two wiring connectors inside you need to pull off their retainer, but do not have to disconnect. One on either side (green and brown).
Before..
Old Apr 9, 2017 | 04:11 PM
GABAR's Avatar
GABAR
I have to tip my hat to you guys who take the time to figure out how to add features to our trucks that didn`t come with them from the factory.
I take it the parts list to figure these things out might be the hardest but I could be wrong.
Thanks for the posting.
Old Apr 10, 2017 | 06:53 AM
Gary Lewis's Avatar
Gary Lewis
First, welcome to FTE! Second, that may be the best-done how-to I've ever seen. Good job!
Old Apr 10, 2017 | 11:25 PM
mdntblu's Avatar
mdntblu
I'm jealous. I want this on my 2016 Expedition (even though it didn't even come standard) haha. I wonder if there is a way to do it? I saw some guy on ford-retrofit website add lane keeping assist to his Taurus that didn't come standard with it.
Old Apr 13, 2017 | 07:19 AM
Frantz's Avatar
Frantz
I was gonna say, you can't list part numbers on a how to thread because then people can actually do it! Thanks.
Old Jun 15, 2017 | 08:56 PM
thayilt's Avatar
thayilt
any suggestions if I can do it on my 2011 explorer xlt ?
Old Jun 19, 2017 | 06:24 PM
Big-Foot's Avatar
Big-Foot
Amazing!
I wonder if it would work on my 2017 ?
I think the option was close to three times the cost of the parts!
Old Jul 23, 2017 | 09:03 AM
****'s Avatar
Originally Posted by Big-Foot
Amazing!
I would love to know as well. Assumption is that it's the same.
Old Oct 3, 2017 | 08:41 PM
btroyer2011's Avatar
btroyer2011
Wanting to install
Hello I was wondering if someone could tell me if its possible to do the ford IDS Calibration yourself and if so how would you do this?
And How difficult would this be to do?
just wanting a more in-depth "tutorial" as i don't wanna screw up or spend all that money and not have it work.
would this void the dealership warranty?
Old Oct 7, 2017 | 08:44 PM
Carnivore's Avatar
Carnivore
i wish I could pay the dealership to do this for me
Old Oct 8, 2017 | 10:17 PM
jwestercamp's Avatar
jwestercamp
does this also apply brakes?
Old Jan 15, 2018 | 02:15 PM
ufvj217's Avatar
ufvj217
kinda old thread, but I believe it does, although I'm not 100% sure, I would like to know for sure myself.
Does anyone know if this is an option on new econolines (i know they aren't made anymore other than cut-away models for box trucks and RV's)..that's what i'm curious for is for a 2017-18+ RV if ford offers this as an option for those. it would be super nice for an RV traveling. I've never used adaptive cruise before personally, but i've seen videos and everyone that has it on their cars loves the feature.
Old Dec 13, 2018 | 01:25 AM
Charles Zimmerman's Avatar
Charles Zimmerman
Help
i know this is a truck forum but hoping that I can get the same list or find a list similar for a Taurus. I have a 2018 SHO but would guess that any 2016+ Taurus would be the same.
Old Dec 13, 2018 | 01:31 AM
mdntblu's Avatar
mdntblu
I wish I could add it to my 2016 Expedition. Would be awesome. I have the Stop n' Go one on my Fusion and it's great in traffic. Never touch any pedals.
Old Mar 15, 2019 | 09:14 AM
MBUSMC's Avatar
MBUSMC
Thumbs up Followed your steps to success
Completed on 2016 Ford F-150 Lariat with 502A package.
I purchased the items identified in the post. The dealer did not want to let me order them after running my vehicle VIN, citing the parts aren’t for my vehicle. I had to agree to no return if the modification didn’t work, but that was a small hurdle.
The parts install was easy. Take your time, remember where everything goes and follow the steps. Everything is basically plug and play. Removing the bumper may have been the hardest part, and that’s only six bolts.
I downloaded FORScan and followed the programming guide provided in the post. You can covert your VIN to hexadecimal using google and a hexadecimal converter. To calibrate the sensor, you have to select the calibration function on FORScan and it will instruct you to drive on a straight road between 30 mph and 50 mph until the sensor activation screen disappears. The distance for me was roughly a mile and a half. Once that was completed, I selected ok, and I was all set.
Great post. Thank you for taking the time to put this together.
