Adding Adaptive Cruise Control - Complete!
Old Sep 18, 2019 | 06:19 PM
ezrdr54's Avatar
ezrdr54
Works Like A Charm!
Originally Posted by Ecoboost_Morgan
Hi Everyone. I am new to this forum, not new to this industry. I have an ongoing thread on another board, but thought I would share on this platform as well.
I have a 2016 F150 502a, this will not work on XLT systems due to the harness behind the dash and IPC screen. Perform this mod at your own risk. The parts list and required FORScan changes are posted below. Enjoy!!!
BATTERY - Disconnect it.
HUD - Easy to remove the blank plate and add in the HUD module. Two retaining clips on either end with the HUD wire connected to the blank. Remove the plate with a small screw driver or trim removal tool - pops right out. Straight forward to install new trim plate and the HUD module. Easiest part of the install!
WIRING HARNESS - The new harness powers fogs and the new CCM module. The connector you can see from the top by the passenger headlight assembly. It lays horizontal in a small triangular space. Getting it out was a challenge until I removed the bumper. Three bolts on either side and the bumper is off and the harness is right there. Knowing what I know now I might be able to get the harness out without pulling the bumper, but only because I've done it one time.
SENSOR MODULE - The new bracket goes in very easy. Level the new sensor and you're good to go using the top alignment screw and a reverse torx socket. Three plastic retainers in the bumper itself; two screws in the top of the bracket to the metal frame behind it.
STEERING WHEEL CONTROLS - Make sure the battery is disconnected and that there were no airbag faults prior to disconnecting the battery. Always keep away from the face of the airbag and handle the unit VERY carefully. If dropped, do not reinstall the airbag. Getting the airbag out with two hex wrenches was easy. You can lift it right out and sit it on top of the wheel assembly. Two wiring connectors inside you need to pull off their retainer, but do not have to disconnect. One on either side (green and brown).
Used your parts list, followed the instructions and Voila! Thanks so much for putting this together! Mine was also a 2016 Lariat 502a. Shout out to MBUSMC as well for the FORScan pointers, "we don't need no stinkin' IDS"!
Old Oct 17, 2019 | 04:07 PM
rssnape's Avatar
rssnape
Anyone done this on a 2019?
Anyone done this mod on a 2019?
Old Oct 17, 2019 | 04:46 PM
smokewagun's Avatar
smokewagun
I’m jealous. I can’t find time to wash my truck, let alone 20 hours to add an option like this. Great job!
Old Dec 27, 2019 | 10:58 PM
James Garlock's Avatar
James Garlock
I did this on my 2017 and it took me about 4 hours at the most. I took my grille off for easier access. Great feature
Old Dec 30, 2019 | 05:05 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Does this mod require the 8" gauge cluster or can you do it with the 4" gauge cluster?
Old Dec 30, 2019 | 05:39 PM
James Garlock
it requires the 8”
Old Jan 1, 2020 | 08:39 AM
jimmyv13's Avatar
jimmyv13
I am very much considering adding this to my raptor, thanks for the wire up! Questions about the sensor...when you say to "level" the sensor, do you mean to make sure it's 90* to the bumper bracket or level with the ground?
Old Jan 1, 2020 | 02:44 PM
James Garlock
this is what he means but “level”. The sensor needs to be pointing straight forward and not up or down too much.
[img]blob:https://www.ford-trucks.com/80bcc578-3f26-42a9-bc55-d1b0eb8e47b3[/img]
Old Jan 19, 2020 | 01:16 PM
MackTX's Avatar
MackTX
2019 XLT 5.0 301A Adaptive Cruise?
Attachment 194218
Before..
Attachment 194219
Attachment 194220
Attachment 194221
Attachment 194222
Attachment 194223
Attachment 194224
Attachment 194225
Attachment 194226
Attachment 194227
Can Adaptive Cruise Control be added to a 2019 F150 XLT 5.0 301A with factory cruise control and Pre-Collision assist?
Old Jan 19, 2020 | 02:17 PM
James Garlock
check this out. Should be possible
https://www.f150forum.com/f118/2019-...cruise-454662/
Old Aug 4, 2020 | 07:15 PM
my3aarons's Avatar
my3aarons
Just performed this upgrade on my 2015 F150 Lariat (502A). Here are a couple of notes:
Don't over complicate the removal of your bumper. The only nuts that you need to remove are the six 21 millimeter nuts. Four are on the front of the bumper (2 on each side) and two are on the back (one on each side).
Also, once you have all of the hardware installed, when you start FORScan, do NOT use your old profile. Create a new one. This forces FORScan to recognize your cruise control module. I did not do this and could not find the C-CM module anywhere until I created the new profile.
I can attest that Ford IDS is not needed. Use FORScan to calibrate your C-CM.
Everything now works as advertised.
Thanks Ecoboost Morgan for this easy to use guide!
Old Aug 24, 2020 | 06:59 PM
Wills16SCrew's Avatar
Wills16SCrew
I'm ready to jump into this mod. I ran the hex decimal output for my vin ('16 Lariat 502a) and one cluster of digits is: 4b. Is this okay to enter into forscan when following the VIN entries? All input is greatly appreciated.
Old Aug 25, 2020 | 09:19 AM
  #28
my3aarons's Avatar
my3aarons
Yep. Being hexadecimal, it can have the numbers 0 through 9 and the letters A through F. Mine also had a '4b' in it and it worked, no problem. FYI, '4b' in hex corresponds to the letter 'K' in your VIN.
Old Aug 25, 2020 | 05:05 PM
  #29
Wills16SCrew
Thank you sir. When disconnecting the battery, just the negative is sufficient (and waiting about 30 minutes before working on removing the steering wheel airbag?
Old Sep 30, 2020 | 01:32 PM
  #30
vinay.gonagunta's Avatar
vinay.gonagunta
Could I add Adaptive Cruise Control and Lane Change Assist for 2017 F-150 Lariat Super Crew 5.5' Box RWD with sports appearance and 501A MID package ?
