starter relay
Old Apr 8, 2017 | 11:15 PM
ftlover90's Avatar
ftlover90
starter relay
hey hows it goin got a question bout my 1990 f150 I just got it a few day ago on trade and they have the fuel pump and ignition rigged up the fuel pumps on a toggle switch and to start it takes two keys and I'm needing help to put back to factory. the first key is the factory one in the collume you turn it on to run and all the lights come and everything then theres another ignition you turn to turn it over and start it. My question is the factory key has a wire that has alittle over 10 volts when you turn to start and nothing any other time the ignition they added has alittle over 12 volts when you turn to start position and nothin any other time but when I connect the factory ignition with the 10 volts to the starter relay it want turn over but it will when the 12 volts is hooked up is 10 volts not enough to activate the starter relay.
Old Apr 9, 2017 | 07:27 AM
Franklin2's Avatar
Franklin2
10 volts is enough for the starter relay. You will get that if the starter is turning. If it's not turning and you are getting 10 volts, then you have a poor connection somewhere.
Old Apr 9, 2017 | 12:38 PM
ftlover90's Avatar
ftlover90
its getting a good connection cause the key with 12 volts starts it up just fine but when I hook up the ket with 10 volts does nothin I'm wanting to have the factory key do everything but I might just remove the key that was installed and put a push button thanks for the help.
dan6915
Jun 11, 2015 10:30 AM
truck7575
Dec 8, 2014 12:40 PM
Chequamegon
Aug 11, 2011 10:47 PM
Tod1985F250
Nov 10, 2009 08:05 PM
wshop2
May 28, 2004 09:28 PM
