No start problem
Old Dec 8, 2014 | 11:36 AM
truck7575's Avatar
truck7575
No start problem
So this past weekend I started my truck... It fired up fine... I moved it and parked it and turned it off... Now I went out and tried to start it and nothing... I have full operation of all accessories but when I turn the key nothing... All the accessories go off when I turn the key just like it used too... I took the starter off and bench tested it and it spun just fine with the gear popping out just like it's supposed too... The starter is less than a year old... Where do I go next? Could someone give me some direction as I don't have money just to throw money at it and I'm able to do some basic testing
Old Dec 8, 2014 | 11:59 AM
FordxFour's Avatar
FordxFour
How old and what condition is your battery in? Fully charged it should be at 12.6 volts. Also check your grounds.
Old Dec 8, 2014 | 12:20 PM
truck7575's Avatar
truck7575
The batteries are about 1.5 years old they were bought new as a pair.. Are there any specific grounds that may be a bigger culprit than others?
Old Dec 8, 2014 | 12:32 PM
andym's Avatar
andym
Turn the key on and short the terminals at the starter relay. If it cranks, it's the relay.
Old Dec 8, 2014 | 12:35 PM
truck7575's Avatar
truck7575
Where exactly in the truck is the starter relay in the engine bay?
Old Dec 8, 2014 | 12:40 PM
FordxFour's Avatar
FordxFour
Start at the batteries and follow the larger cables. If they are loose or are corroded, clean and tighten. If it were me I would make sure that the batteries were in top notch shape before doing anything else.
Does this truck sit for long periods of time. If so, you may want to look into investing in a battery maintainer(not a trickle charger)to keep the batteries in peak condition, I now use CTEK's on all of my trucks if they are going to sit for over a couple of weeks. I got tired of replacing batteries due to sulfation.
Singing River Farm
18
Jan 25, 2014 03:51 PM
ju015dd
Nov 17, 2010 07:55 PM
snowmobiler7c
Jun 14, 2009 06:42 AM
BeltDriven
Apr 26, 2006 06:54 PM
glcarpe
Feb 6, 2006 02:07 PM
