Engine swap
Old Apr 8, 2017 | 03:54 PM
Kirbyray382's Avatar
Kirbyray382
Engine swap
Hi I just pulled a old 6.9 idi out of my 1986 f250 4 speed manual 2wd pick up and want to know is the old wiring harness good for the 7.3 idi
Old Apr 8, 2017 | 11:13 PM
Macrobb's Avatar
Macrobb
They are basically the same engine. If you use all the 6.9 glow plugs and controller, you can use the 6.9 harness. Otherwise, you'll need to modify it or use a 7.3 harness if you want the 7.3 plugs and controller.
Old Apr 9, 2017 | 12:24 AM
genscripter's Avatar
genscripter
When I swapped my 7.3 for a 6.9, I kept the 7.3 wiring harness and GP's. The GP's thread the same into the heads, but the electrical connectors on the tops of the GP's are different between the 7.3 and 6.9.
irhunter
Dec 2, 2015 08:18 AM
mike manglos
Mar 1, 2012 04:37 AM
knash0727
Jul 13, 2010 01:41 PM
skoto1
Feb 4, 2008 10:57 AM
PlaidassSurf
Mar 4, 2007 03:34 PM
