Which grease types are compatible with OEM?
Old Apr 8, 2017 | 07:15 AM
2009kr's Avatar
2009kr
Want to grease the fittings on my new F450... I want a great grease, but am not sure what is compatible with the factory grease. The specs only seem to mention the moly and zinc additives. Is the grease thickening agent calcium, lithium, etc.? Any recommendations for the chassis grease?
Old Apr 9, 2017 | 06:42 AM
2009kr's Avatar
2009kr
Nobody knows? My understanding is that you can cause big problems mixing incompatible greases. Maybe I'll just stick with the inexpensive Motorcraft grease of I can't find the answer.
Old Apr 9, 2017 | 06:58 AM
dieselss's Avatar
dieselss
As long as there's grease in the there that's the main concern
Old Apr 9, 2017 | 07:10 AM
RJC2's Avatar
RJC2
I think that I would just stick with the Motorcraft grease, you know it will work. It would be a shame to try a high dollar product that turned the existing grease into a watery mess and ruin something.
Old Apr 10, 2017 | 10:31 PM
2009kr's Avatar
2009kr
I never greased the suspension or ball joints on my 2009 F150 (no fittings) and they are 7 years old with 145k miles and still going strong. I guess the Motorcraft grease is good enough.
Old Apr 10, 2017 | 10:40 PM
RJC2's Avatar
RJC2
I think he's referring to joints with fittings.
Old Apr 11, 2017 | 03:48 AM
dsladdict's Avatar
dsladdict
If you look in your manual, page 420-421, lists the Ford specification for the grease and the part number if you just want to go to the dealer and purchase the Motorcraft grease(best if you are really concerned about it or are unable to find a grease that is marked as meeting the Ford specification). It lists both a high temperature grease and a mulit-purpose grease.
Spindle bearing: WSS-M2C192-A
High Temperature 4x4 Front Axle and Wheel Bearing
Grease
XG-11
Multi-purpose grease: ESB-M1C93-B
Motorcraft® Multi-Purpose Grease Spray
XL-5-A
Old Apr 11, 2017 | 06:03 AM
Xwild's Avatar
Xwild
Where are the grease fittings on the 2017s? I never greased anything on my 2010...
02superstroker
Jul 15, 2015 12:59 PM
pawpaw
Oil & Lubrication
Nov 26, 2013 04:38 PM
obscurity
Aug 26, 2013 09:18 AM
Freaksh0w
Oil & Lubrication
22
Apr 24, 2011 08:02 AM
BlueOvalFitter
Feb 26, 2007 05:11 PM
