E4OD shifting issue after rebuild
Old Apr 13, 2017 | 11:29 AM
cjgodden's Avatar
cjgodden
wish I would have found this before I put the trans back in.
1996 Bronco/F-Series Workshop Manual
Would have been helpful then, well unfortunatly I did not find the problem yet, but i am determined, and now i have the workshop manual. will post when i figure it out.
Old Apr 13, 2017 | 07:23 PM
cjgodden's Avatar
cjgodden
Looking for advise on this, seperator plate has some pitting, it looks to be only in the oil gally areas, could this be the cause of the leaking, I have narrowed this down to the valve body, air pressure tests confirm the pistons internally are working properly. Or should the gasket still seal.
Old Apr 17, 2017 | 06:00 PM
cjgodden's Avatar
cjgodden
So It is fixed and working properly now, the problem was in the valve body, not exactly sure what it was but here is what i did. I went and purchased a transgo shift kit, my thinking on this was that it would replace any springs of known issues in the valve body, i installed the shift kit as per directions for tow/haul, I removed all other valves and reinstalled just to make sure they were moving freely, after seeing the seperator plate and its condition I took a good look at the surface of the main valve body, and it did not look like a shiny flat surface, with a straight edge I could not fit feeler guage under it, but the surface was suspect. So i glued some 400 grit wet sandpaper to a thicker sheet of glass that i have, and using the weight of the valve body I sanded the surface, taking it real easy and making sure it stayed flat. as I progressed I could see that the center section took some time before it started to clean up, so there was a difference in height, not that I could measure, but it was there. After i got a nice clean surface, i cleaned the valve body and reinstalled, and it shifts great, second gear is solid and I am very happy. I did reuse the seperator plate as I could not find one locally, So I either had a shift valve sticking or the valve body was leaking and sanding the surface did the trick.
Old Apr 17, 2017 | 06:12 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Good work!
Kdr358
13
Mar 1, 2014 05:04 PM
FORD MEGA CAB!!!
Jul 6, 2012 08:40 PM
dbcooper
Mar 31, 2011 12:20 PM
dbcooper
Mar 31, 2011 09:21 AM
