E40D aftermarket speedometer
Old Apr 7, 2017 | 05:01 PM
52M37's Avatar
52M37
I got a 1952 Dodge ambulance sitting on a 1993 Ford F-250 7.3idi automatic. I'm trying to hook up an aftermarket speedometer. My questions is what wire do I use to get the pulse signal into the new speedometer. Do I have to keep the old speedometer for the transmission to shift properly? I could hide it under the dash if that is the case. I found the VSS on top of the rear differential but I'm not sure if that is where I find the signal. Any help would be appreciated. Ford speedometer not looking very good
This is the aftermarket speedometer I'm trying to hook up.
Old Apr 11, 2017 | 05:06 PM
JP3's Avatar
JP3
We hid the old speedo in the dash. The trans controller needs a square wave 8000 pulse per mile signal and the stock speedo does a fabulous job of creating that from the diff mounted speed sensor's AC signal.
We tapped into that same 8k ppm signal output (grey w/black) to drive our Autometer electronic speedo. Then we went through the Autometer calibration routine and it has worked great ever since.
Old Apr 11, 2017 | 06:07 PM
52M37's Avatar
52M37
Thank you for that info and the diagram!
S7AN
Jun 14, 2018 03:03 PM
bigblockford_390
Large Truck
Jun 10, 2018 09:42 PM
a2zmatt67
Jul 24, 2017 03:39 PM
forddieselnewb
21
Dec 28, 2012 10:54 PM
rcav8or
Mar 6, 2008 07:20 PM
