Brakes Suddenly Out without Warning?
Old Apr 7, 2017 | 03:10 PM
76f350spercamprspeal's Avatar
Went to drive my 95 to work in the beautiful weather. Stopped at the post office. Went to leave and Brake light and ABS light were on. ABS light goes on and off. Petal foes to floor with no pressure what so ever. Truck barely stops. Burnt smell and brake fluid is full. Is my master cylinder out? Is my brake proportioning valve out? Why would the ABS light be on as well...
Any help would be appreciated. Made it back home safely. Luckily wife wasn't with me.
Old Apr 7, 2017 | 03:15 PM
madpogue's Avatar
madpogue
Did you inspect the calipers, wheel cylinders and ALL hydraulic lines for a leak?
Old Apr 7, 2017 | 03:30 PM
rla2005's Avatar
rla2005
The Red Brake light means the reservoir is not full. The Yellow ABS light means the RABS control module senses a problem. You have to get the Red Brake light off before you can pull the brake codes.
Are you sure the reservoir is full?
For reference:
Old Apr 7, 2017 | 04:11 PM
seagiant's Avatar
seagiant
Hi,
Don't forget the MC could have an internal leak and you would still have fluid in the system.
This is a small Hydraulic System of course and ANY leak is BAD!
Old Apr 7, 2017 | 05:10 PM
MoBill122's Avatar
MoBill122
Papa Smurf
If no leaks, I'd place my bet on a new Master cyclinder. Same thing happened to me... glad to have emergency brakes to stop with in traffic !
Old Apr 7, 2017 | 06:03 PM
I'm positive it's full. I was thinking master cylinder as well.
Old Apr 7, 2017 | 07:53 PM
seagiant's Avatar
seagiant
Hi,
I don't know how old your MC is?
But if you want to test it, get the right size plugs to plug the brake line holes.
Top off the reservior.
Try the pedal.
If it firms up hard your MC is good.
If not and it sinks or is spongy it is bad!'
This lets you know where the problem is anyway!
stan'37
Oct 24, 2017 02:52 PM
1990f150dude
Oct 8, 2012 07:00 PM
Barnyrad
Apr 10, 2008 08:42 PM
brianamb
Aerostar
May 20, 2007 12:58 PM
rywegh
1978 - 1996 Big Bronco
Aug 14, 2004 01:11 PM
