Sponsored by: Innova
won't start
Old Sep 1, 2003 | 03:22 PM
chris69's Avatar
chris69
won't start
i have a 1978 f- 150. last night the battery was dead so we jump started it and i let it idle for about 25 minutes to get a good charge on the battery. after about 25 mins of idling it died. i went out and started it back up. it wouldnt hold an idle. i shut it off. in the morning i tried to start it back up and it ran for about a second. then i tried again and it cranks but it doesnt even try to start up. what is wrong. is it flooded is ot out of gas is something wrong in the ignition. is there water in the engine
Old Sep 1, 2003 | 08:27 PM
luvdeftonz's Avatar
luvdeftonz
won't start
This is the audio section. We're pretty dumb unless you're inquiring about your stereo system Try one of FET's other forums.
Old Sep 2, 2003 | 07:06 AM
PrPlayboy's Avatar
PrPlayboy
won't start
Considering it's a 78 it should be hard to figure out. Checking the gas is easy but it the battery was dead, doubt it was on E. Was it sitting for a long time before the battery went dead? It could be a number of things but this is the audio section. I have seen bad starter motors drain a battery and cause all types of problems.
Flipcarroll
4 Cylinder Engines
Jan 27, 2017 03:08 PM
Pebcak
37
May 27, 2016 08:45 PM
Picky1962
May 8, 2016 11:19 PM
kincfu
15
May 3, 2016 06:12 AM
Krisx125
Jan 11, 2010 11:26 AM
