1995 f150 shifter stuck in 3rd gear
Old 04-11-2017, 02:37 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
Originally Posted by sandymane
Those look like they came from the electrical connection opening.
Theye all 3 came out if this hole
  #197
Old 04-11-2017, 02:43 PM
sandymane's Avatar
sandymane
sandymane is offline
Ok Put the long piece in the big hole the shaft goes into. It will go in sideways. There should be an opening on one side for it to slide in. Then from the top put the spring in and the ball on top. Depress and put the shaft back through.
  #198
Old 04-11-2017, 04:10 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
I can't get my ****ing rods back through
  #199
Old 04-11-2017, 04:13 PM
sandymane's Avatar
sandymane
Tell me what the problem is. And which rod are you working on?
  #200
Old 04-11-2017, 04:15 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
not the center rod the other seems to be getting stuck on the ball bearing or that other side pice that fell out
  #201
Old 04-11-2017, 04:26 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
See how the side pin is stopping it from going through I dunno what else to do I can't get it to go in
  #202
Old 04-11-2017, 04:48 PM
sandymane's Avatar
sandymane
Is the middle shaft back in?
  #203
Old 04-11-2017, 04:50 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
Yeah the middle shaft is in
  #204
Old 04-11-2017, 05:01 PM
sandymane's Avatar
sandymane
We never talked about putting that shaft back it. You were supposed to put the bottom one in first. It will be a lot easier if we take the proper sequence to get this done. Let's not get ahead of ourselves .
Push the bottom shaft back out and remove the bearing and spring and the sideways pin. THEN push the center shaft back out watching out for parts. THEN put the lower shaft parts back in and put the shaft in. It will go this time. Let me know when you have done ONLY this.
  #205
Old 04-11-2017, 05:02 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
ok I gotta run my daughter to school but when I get back I will do this!
  #206
Old 04-11-2017, 05:03 PM
sandymane's Avatar
sandymane
Ok we will get it.
  #207
Old 04-11-2017, 07:15 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
Ok we will get it.
This is as far as I can get the outside rod in
  #208
Old 04-11-2017, 07:40 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
Ok we will get it.
I could scream!
  #209
Old 04-11-2017, 07:41 PM
sandymane's Avatar
sandymane
Has the center shaft cleared the hole on the right? If not make it clear the hole and watch out for parts. Then tap or lightly hit the end of the bottom shaft so the end of the left side of the shaft is just at the edge of the opening. Look at it on post 56. You want it to look like that. Page 4
  #210
Old 04-11-2017, 07:48 PM
Ksanglem's Avatar
Ksanglem
Ksanglem is offline
Success or just a tiny bit more?
Quick Reply: 1995 f150 shifter stuck in 3rd gear
