Big flow air intake?
Old Apr 6, 2017 | 09:17 AM
jcthorne's Avatar
jcthorne
Need some recomendations on air intakes. Turns out the Donaldson Air Intake System with the spiral element filter cannot flow enough air to feed a GT38R turbo on a 7.3. Trips the filter minder and collapses the intake air hose as the turbo winds up. I need a less restrictive intake but would prefer one that filters well too for long life. Cost aside for the moment what are the best options for big air flow and good filtration? I don't mind needing to clean the filter even each oil change interval if necessary. I was looking at this AFE intake as a possibility but perhaps there are better options. None of the ones that are supposed to sit on top of the stock air box will work, I do not have a stock air box.
Old Apr 6, 2017 | 09:33 AM
CampSpringsJohn's Avatar
CampSpringsJohn
This system flows better from what others have said. I have the Ford AIS and agree that it doesn't flow what it needs to with a modified truck.
S&B 7.3L Powerstroke Cold Air Intake Kit - Dry - New Design - Riffraff Diesel Performance
I will see if this thread can be moved to the 99-03 7.3 PSD forum as well. A lot of good folks there, all with opinions!
Old Apr 6, 2017 | 09:35 AM
Tom's Avatar
Tom
Moved to the 7.3L forum.
Old Apr 6, 2017 | 11:16 AM
Stewart_H's Avatar
Stewart_H
AFE "Big Boost" BHAF Washable Filter Ford 7.3L Powerstroke
Stewart
Old Apr 6, 2017 | 11:54 AM
Tugly's Avatar
Tugly
I use the S&B, as much as I hated to get rid of the AIS. My reasoning? S&B is about as quiet as the big breathers get. Clay has the flow numbers, so it might behoove you to call him directly at Riff Raff Diesel and allow him the opportunity to share those numbers.
Old Apr 6, 2017 | 05:01 PM
Steelheader87's Avatar
Steelheader87
Bit of a hijack, but related, the AFE Big Boost will flow better than the 6637 and lower EGT's?
3000gtman
21
Jan 15, 2017 05:19 PM
MurderMode
Oct 18, 2012 12:09 PM
MD V10
Modular V10 (6.8l)
Jun 22, 2005 03:21 PM
Don_Raja
1997 - 2003 F150
Sep 20, 2004 07:55 PM
trooperkelly
Aug 7, 2003 09:33 AM
