Removing engine - other maintenance?
Old Apr 6, 2017 | 11:20 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
No, but they should be.
Old Apr 7, 2017 | 07:01 AM
Macmathews's Avatar
Macmathews
Tag this great thread !
Kyle
Old Apr 7, 2017 | 08:02 AM
andym's Avatar
andym
I would also pull the injectors while you have it apart that far and check or replace the injector o-rings. Mine had only 185k on it and I was pretty surprised by their condition. Most of them came out in pieces.
There are oil rail and fuel rail end plugs on each cylinder head. All have o-rings.
Take a good look at your idler and tensioner pulleys. Mine were nearing the end of their life.
Old Apr 7, 2017 | 04:30 PM
bkgeig's Avatar
bkgeig
If you're going through the effort to pull it, I'd do a compression test first. I bought mine at 195k miles, history unknown, and am rebuilding the engine at 235k. I don't think it makes a lot of sense to do a bunch of stuff "around" the block without knowing the internal condition.
You don't need to pull it to replace the pan, btw. Diesel Tech Ron has some videos on lifting the engine enough to remove the pan, I think.
Old Apr 15, 2017 | 06:27 PM
Corndwg01's Avatar
Corndwg01
I've seen one for the older trucks, is there any kind of turbo mounting gasket? Secondly, I hope not to have to fool with these, but what about taking off the exhaust manifolds and remounting with new gaskets and studs?
Old Apr 15, 2017 | 06:31 PM
andym's Avatar
andym
No gasket for the turbo, just a pair of o-rings on the pedestal.
I wouldn't mess with the manifolds unless you know there's a problem.
kthemurphy
Jan 23, 2016 09:23 PM
Wiemannm6678
1983 - 2012 Ranger & B-Series
Sep 14, 2014 10:29 AM
Jeepincj7
19
Nov 10, 2012 03:37 PM
rmalottwtes30
Aug 17, 2008 11:43 AM
BottomFeeder
27
Sep 27, 2006 01:03 AM
