Gooseneck hitch and 5th Wheel RV ?
Old 04-04-2017, 04:12 PM
DetailerDave's Avatar
DetailerDave
DetailerDave is offline
I purchased a 36' RV that has a 5th wheel setup. My tow vehicle has a gooseneck hitch in the bed. Is it possible to rent some sort of adapter to move the RV? I don't want to spend $500 +- to buy an adapter as the RV will only be moved locally from it's present location to it's new "home" one time. Distance is no more than 15 miles guesstimated, no freeway, only surface streets and speeds. The only other option is to find someone with a 5'er setup tow vehicle.
Old 04-04-2017, 05:12 PM
69cj's Avatar
69cj
69cj is offline
For a one time move, I'd pay someone with the proper equipment to do it. That's just me. 15 miles won't kill the bank.
Old 04-04-2017, 06:48 PM
SecondChance's Avatar
SecondChance
SecondChance is offline
DO NOT install a gooseneck adapter on a fifth wheel RV. The leverage and torsional forces applied by a gooseneck adapter put undue stress on the pin box and frame of a fifth wheel RV. It may result in frame failure and most likely will void any frame warranty on the RV. There are any number of fifth wheel hitches that will mount to the truck using the gooseneck ball (B&W Companion, Andersen Ultimate, PullRite UltraLite, etc.) but are still standard fifth wheel hitches. If it's just one time, find someone to do it for you as suggested.
Rob
Old 04-05-2017, 10:21 AM
senix's Avatar
senix
senix is offline
Received 1,427 Likes on 1,020 Posts
I'd second the option of getting someone with a 5th wheel hitch to move it for you.
If you don't know of anyone or trust them then I would go to a RV dealer and see if they have someone that will do the job.
Old 04-05-2017, 03:32 PM
Desert Don's Avatar
Desert Don
Desert Don is offline
Received 4,656 Likes on 1,652 Posts
^^^^^here you go!!!! Probably the cheapest in the long run!!!!
Old 04-06-2017, 12:31 PM
msgtord's Avatar
msgtord
msgtord is offline
The cheapest adapter on etrailer is over $400.00. You can pay someone to move it for you a lot cheaper. Check the RV section of Craigslist.
Old 04-06-2017, 10:06 PM
DetailerDave
The issue has been resolved. Going to have someone move it for me. Thanks for the responses.
Old 04-11-2017, 11:27 AM
HDBiker67's Avatar
HDBiker67
HDBiker67 is offline
If i lived out there I'd do it for a case of beer... just sayin'...
ngng
6.7L Power Stroke Diesel
26
04-09-2014 10:48 AM
RogueSpear2023
Fifth Wheel & Gooseneck RV Towing
03-12-2008 09:38 PM
MMarty
03-06-2007 04:52 PM
live2hunt
17
01-22-2007 11:00 PM
Kidby
10-07-2005 12:52 PM
Quick Reply: Gooseneck hitch and 5th Wheel RV ?
