Gooseneck hitch and 5th Wheel RV ?
I purchased a 36' RV that has a 5th wheel setup. My tow vehicle has a gooseneck hitch in the bed. Is it possible to rent some sort of adapter to move the RV? I don't want to spend $500 +- to buy an adapter as the RV will only be moved locally from it's present location to it's new "home" one time. Distance is no more than 15 miles guesstimated, no freeway, only surface streets and speeds. The only other option is to find someone with a 5'er setup tow vehicle.
DO NOT install a gooseneck adapter on a fifth wheel RV. The leverage and torsional forces applied by a gooseneck adapter put undue stress on the pin box and frame of a fifth wheel RV. It may result in frame failure and most likely will void any frame warranty on the RV. There are any number of fifth wheel hitches that will mount to the truck using the gooseneck ball (B&W Companion, Andersen Ultimate, PullRite UltraLite, etc.) but are still standard fifth wheel hitches. If it's just one time, find someone to do it for you as suggested.
Rob
Rob
ngng
6.7L Power Stroke Diesel
26
04-09-2014 10:48 AM
