Rough Idle after "spirited" driving
So last night I got on it a couple times coming home from dinner (just a couple WOT from 25-60) and this morning when cranking it up I noticed the engine developed a rough idle. Also, the typical whistle I hear that kicks in a few seconds after startup is not as pronounced as it was. I've done as much reading and searching of the topic as I can but am a bit stumped at this point (i'm also new to the diesel world so theres plenty to learn).
With my scangauge hooked up I checked out the ICV values (which appear to be good .25 before startup .84 at idle) ICP (22% at idle 48% at 3-4k rpms) and FICM Voltage (47.5v consistently).
The truck is a 2004 6.0L Excursion (255k miles, w/ headstuds, EGR delete, 4" exhaust, blue spring mod installed yesterday) with a rev-x in the oil and ford cetane booster at each fill-up. One of the issues that I'm currently battling though is that the last owner bought the truck with all mods already done, so he wasnt knowledgable as to what is done. There's definitely a tune on the truck as well (seen boost upwards of 38lb), but no tuner with the truck (something I also have to address).
Here's a video of startup if it helps
