Front bump stops
Old Oct 12, 2017 | 11:38 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Originally Posted by msuser92
I had replaced my original bump stops with OEM years ago. Now those are disintegrated as well. I had thought of making some out of hard wood. Do you think that would be too stiff, or does the rubber/plastic ones not provide much cushion anyway?
The rubber is designed to compress albeit at a very high spring rate and be the last inch of your suspension.
As long as the axle is moving upwards it is not bending. As soon as the axle makes solid contact and stops moving then it starts bending and breaking.
Old Oct 13, 2017 | 10:04 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Originally Posted by andym
Yep, even with the V codes and slight lift that comes with them. They have definitely been squished a couple of times by the look of them. Note that I don't slow down for speed bumps, potholes, railroad tracks, etc. so that may have something to do with it.
Originally Posted by Stewart_H
Back in '06 when I did the spring mod, I cut my bump stops. The 2000 MY Excursion had the old style ribbed stops and mine weren't destroyed by the time I did the mod, so I cut the bottom two ribbed portions off.
When this thread was created back in April, I used the same link Mark posted and bought the same stops and replaced mine, which indeed showed contact even after I had shortened them, and done the V's.
I was surprised because the first few years after the mod I constantly checked them, but I stopped looking after awhile. Just never thought about it until I Andy posted this thread.
Stewart
fine, twist my arm.
my 2002 never contacted after lift. no evidence yet on this 2000. But Pirate brings up a valid point. I also slow down considerably for all bumps I see. Guess I'm going shopping
Old Oct 13, 2017 | 09:31 PM
hasteranger's Avatar
hasteranger
I bought the energy suspension ones that mount with a single bolt. Stock ones mounted with two bolts but rest assured the center bolt is under there.
​​​​​​My factory ones were completely gone, metal to metal. Even with v codes and leveling leads, I'm apparently kissing the stops every now and then from the looks of things.
Old Feb 19, 2019 | 03:24 PM
J.A.'s Avatar
J.A.
Dorman Front Bump Stops
They are Dorman brand. They fit fine and they're still in one piece. They've seen some contact too, so if yours are shot I would replace them. They're part of the truck's suspension.
Hi Folks, sorry to bring up an old thread. Could someone please tell me what the hole spacing is on those bump stops? And the diameter of the base? They look perfect for what I need but I can't find the dimensions listed anywhere and I've been googling for hours! Any help would be appreciated.
Chainsaw1062
Sep 28, 2024 01:05 PM
dagwood57107
Jun 23, 2019 03:55 PM
Will Sexton
1997 - 2003 F150
Dec 30, 2015 08:00 AM
Roger T. Pipe
Oct 11, 2009 05:58 PM
Neckkbone
Jan 30, 2004 11:43 PM
