Front bump stops
The bump stops on the front of my Ex have almost completed their transformation into tiny crumbles of dried out rubber. Does anyone know of a supplier that sells replacement bump stops that are not outrageously expensive and fit without modifications? I neither want to pay $90 for a pair of bump stops, nor drill the frame to accommodate a $12 pair. Surely there is a middle ground somewhere?
How is $18.00?
1 Attachment(s)
Mark is spot on.
I used these about a year ago on my 03, going to do the same on my 02 truck that I just picked up. Photo for reference: Attachment 194486 |
I saw these but Amazon says they don't fit my 2000 Ex. Do these really fit without modification?
Originally Posted by andym
(Post 17087656)
Yep
Amazon is wrong frequently about what fits. I always go to the manufacturer's website and look up the part number before checking Amazon for price.
Originally Posted by mecdac
(Post 17087717)
Yes, Amazon relayed similar bad info re: my 2001.
Ok... two of them on the way. Thanks guys!
How did the Amazon bump stops work out? Were they the Dorman brand?
They are Dorman brand. They fit fine and they're still in one piece. They've seen some contact too, so if yours are shot I would replace them. They're part of the truck's suspension.
I bought a set of the same stops from the link above, to replace the OEM fronts that finally completely disintegrated, that I discovered after checking, after reading this thread, which reminded me to do so.
Stewart |
(Post 17512577)
I've always believed they were useless after the lift. Guess I should replace my crusted/missing ones lol |
I took 2 of the rear bumpstops off a totaled F250 at work and cut them down to the right height. Then remove the 2 mounting bolts and bracket for the old front bump stops, there is a mounting hole under the old bump stops that fits the new ones perfectly. Cost me nothing. I found 2 more to replace the traction bars too!
I had replaced my original bump stops with OEM years ago. Now those are disintegrated as well. I had thought of making some out of hard wood. Do you think that would be too stiff, or does the rubber/plastic ones not provide much cushion anyway?
Originally Posted by Tylus
(Post 17521367)
I know the PSD is heavy...but you've actually had them contact?
(Post 17521367)
I've always believed they were useless after the lift. Guess I should replace my crusted/missing ones lol When this thread was created back in April, I used the same link Mark posted and bought the same stops and replaced mine, which indeed showed contact even after I had shortened them, and done the V's. I was surprised because the first few years after the mod I constantly checked them, but I stopped looking after awhile. Just never thought about it until I Andy posted this thread. Stewart |
