Roller cam setup
Old Apr 3, 2017 | 06:27 PM
Hwklein88's Avatar
Hwklein88
Roller cam setup
i have a 68 with a 302 and currently undergoing an engine rebuild. Looking to convert to a roller cam setup. Any recommendations on brands/kits? Any draw backs to a roller cam setup on a 77 302?
Old Apr 4, 2017 | 12:00 AM
GaryKip's Avatar
GaryKip
I can't imiage any drawback to a roller system, less friction, less heat.
Old Apr 4, 2017 | 01:47 AM
'65Ford's Avatar
'65Ford
There is no downside. The best part is you won't have the fear of wiping the cam and won't need high zinc oil.
I recommend having a builder who is experienced with your particular motor put together a package for you. It's important to get the right cam, lifters, valve springs, distributor gear, etc for a roller setup.
Old Apr 4, 2017 | 08:26 AM
orich's Avatar
orich
2x per 65Ford.
Also for the type of driving you'll be doing with that sbf. engine if auto trans or stick tranny.
Don't get a wild cam just for the sound of it.
Orich
Old Apr 4, 2017 | 11:10 AM
Hwklein88's Avatar
Hwklein88
Originally Posted by orich
2x per 65Ford.
Orich
he sent me this one to look at this morning. He said this would be all I need with the other parts I ordered. Opinions? Automatic, daily driver. http://www.jegs.com/i/Comp-Cams/249/CL31-218-2/10002/-1?CAWELAID=1710533524&CAGPSPN=pla&CAAGID=446935921 61&CATCI=pla-208205376791&catargetid=230006180039216833&cadevic e=m&gclid=CIri0M2Xi9MCFQiSaQodxakDIg
Old Apr 4, 2017 | 11:46 AM
smoky_diesel's Avatar
smoky_diesel
Originally Posted by Hwklein88
he sent me this one to look at this morning. He said this would be all I need with the other parts I ordered. Opinions? Automatic, daily driver. COMP Cams CL31-218-2: High Energy 268H Hydraulic Flat Tappet Camshaft & Lifter Kit Lift: .456" /.456" Duration: 268°/268° RPM Range: 1500-5500 | JEGS
This link is for flat tappet cam. Looks like you need a small base cam with roller lifters to use with the conversion kit in an old non roller block.
218/268 is about the most duration I would run for a DD. Above that you may not have much vacuum for pwr brakes.
Old Apr 4, 2017 | 12:26 PM
hivoltj's Avatar
hivoltj
I would use Howard's link bar lifters if u have a non roller block. Mild cam from comp's XE line would fit the bill nicely
Shwan_89HD
Oct 4, 2013 05:29 PM
josh tipton
13
Jan 31, 2012 09:43 AM
McMaster
Dec 7, 2010 06:53 PM
xfordman
4 Cylinder Engines
Oct 19, 2010 07:57 PM
DcSkater602
Jan 13, 2005 07:21 PM
