need cam choice help
Old Jan 29, 2012 | 07:46 PM
josh tipton's Avatar
josh tipton
i have a 1991 f150 5.0 speed denisty motor and need help in finding a mild to choppy idle cam or the best proformance cam i can use with out having issues with computer and tuning being messed up and also how do i know if its roller or not
Old Jan 29, 2012 | 08:18 PM
SCRebel's Avatar
SCRebel
You should have a flat tappet cam. I don't believe the 5.0 went roller in the F series or Bronco until 94.
Old Jan 30, 2012 | 05:09 AM
lew52's Avatar
lew52
The 91 will be flat tappet , if you want to go to a roller cam you need to find a 302 HO , or a 94 + truck motor , you can get the spider retainer , dog bones , roller lifters , out of one of those . The HO cam with 1.7 rockers with work with SD , you would also need the distributor or the steel gear for the roller cam , or just stay flat tappet , i like roller cams....Lew
Old Jan 30, 2012 | 10:33 AM
Conanski's Avatar
Conanski
Forgetaboutit.. a cam that produces a choppy idle and speed density are not compatable. There are several upgrade cam options for these trucks but they will all produce a smooth stock like idle. The cheapest option for you is the Comp cams 31-255-5 flat tappet cam and lifter kit, your motor should be roller ready so you could potentially swap in a roller cam but the cam alone will cost double what the flat tappet kit does and you still have to buy roller lifters, pushrods, and the spider and dogbones retainer assembly.
Old Jan 30, 2012 | 11:16 AM
strokin'_tatsch's Avatar
strokin'_tatsch
My '92 truck 302 was roller from the factory.... Just an FYI.
Old Jan 30, 2012 | 01:19 PM
Conanski's Avatar
Conanski
Yep.. they started appearing in the '92 model year in the 5.0 but not until '94 in the 5.8.
Old Jan 30, 2012 | 04:13 PM
wicat3's Avatar
wicat3
might be a stupid question but how do you tell if you have a roller cam or a flat cam? I have a 92 and was going to look into cams for it but know im not sure what i have.
Old Jan 30, 2012 | 04:25 PM
Conanski's Avatar
Conanski
You will have to pull the drivers side valve cover off and put a light down the front pushrod hole, if you see a dogbone around the lifter you have a roller cam. See pic below, the dogones are the fork looking things around the lifter body.
Old Jan 30, 2012 | 04:47 PM
wicat3's Avatar
wicat3
the dog bones are the things holding the lifters in and the windage tray is holding them down?
Old Jan 30, 2012 | 05:12 PM
lew52's Avatar
lew52
The dog bones keep the lifters from turning , the retainer ( not a windage tray ) keeps the dog bones in place , roller lifters can not turn in the bore like a flat tappet cam because of the roller ,....
Old Jan 30, 2012 | 07:10 PM
josh tipton
well guys turns out my motor is a roller motor, with a 1991 intake and plenuium and fuel injectors now i just need to pick a good cam out that wont mess up my computer.
Old Jan 30, 2012 | 08:08 PM
wicat3's Avatar
wicat3
thanks for the info lew that makes sense
Old Jan 30, 2012 | 10:25 PM
Conanski's Avatar
Conanski
In that case I'd suggest the Comp 35-512-8 roller cam.
Old Jan 31, 2012 | 09:43 AM
SCRebel's Avatar
SCRebel
Can you find a roller 5.0, like a 1992 5.0, and use those parts to make a roller 351w? Or do you just have to get a F4 351w block?
Shwan_89HD
Oct 4, 2013 05:29 PM
xfordman
4 Cylinder Engines
Oct 19, 2010 07:57 PM
fomoconate
May 19, 2009 09:44 PM
dutchboy
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 6, 2004 02:07 PM
