Ford Racing Engine Harness MAF Conversion
1). Says to make a mandatory connection to the check engine light with two wires, one positive, the other negative. Being there is no existing check engine light just an emissions light, how can these be connected?
2) says to connect one wire to the + side of the fuel pump but if over 25 amps route though a relay. What does the factory pump draw amp wise? Also since the new wiring harness has its own inertia switch with the wiring layout different, I'm thinking I can just use an aftermarket relay, the new wire cuts on the relay, then run a solid battery source to the relay for the fuel pump. In other words, is there any reason to maintain the original factory relay? But also what tells the fuel pump to cut off if demand is not there?
3) the new harness has a wire that says to connect to dash control ac switch. Being there is no such thing what do I need to do? Truck does have ac.
4) lastly, and not a mandatory connection, but a lead to the tachometer. Being I have that own conversation done to the cluster previously I'm thinking just leave this one unconnected.
- Use the Emissions light
- You can find the wiring schematics here: 1986 EVTM - ???Gary's Garagemahal. But, for this question start with the fuel pump control here: Electric Fuel Pump Control - ???Gary's Garagemahal. Then you'll see in the upper left on Page
- 3103 that you need to go the pages 60 & 63, here: Electronic Engine Control - ???Gary's Garagemahal. But none of that tells how much current the pump pulls. I can't answer that as mine is a carb'd 460, but it doesn't pull all that much. I was surprised that an 1156 test light actually ran my pump, although only for a few psi.
- The AC connection is so the idle will compensate when the compressor comes on. So, disregard.
- The negative side of the coil serves the tach.
1) In the case of the emissions light, what is controlled by? I suppose the best way to tap is is behind the plug at the cluster?
2) I've followed the fuel pump wiring diagram but the wiring of the existing and the new harness are not the same. In the existing wiring, does the fuel pump run all the time? If it does anyway, would I be correct by adding a regular relay to trigger it without worry of it running all the time? But if the engine is not running, but key is on, what trips it off?
3) I do have ac on the truck. The instructions for this wire indicates that it activates the ac clutch. If it actually only receives information, I'm thinking tap it into one of the wires already on the ac that becomes hot when the clutch is powered.
On the fuel pump wiring, go look at the wiring for the 7.5L, which is what I've been working on in Big Blue. It has an oil pressure switch that is in the coil circuit of the fuel pump relay. I'd add one of those to ensure that the pump only runs when the engine is running. And, don't miss the part where the fuel pump comes on during cranking.
On the AC, I really don't know what to tell you. But, I thought it was just to tell the computer that the compressor is on rather than to control the compressor. Perhaps you can get everything else going and then test that?
As for the emissions light, I wish I knew what controls it. Here's the one on Big Blue:
When the key is first turned on, the computer primes the pump and then it stops. When it see's signals from the distributor then it assumes the engine is turning and it turns the pump back on, using the relay on page 103 in this link.
https://www.summitracing.com/parts/sum-900402
The tool pushes in the tab and you pull the part out.
If you have a box in hand it should be easy to see the tab to release it.
Dave ----
Factory wiring has two wires to the relay that connect to the eec. Of these the red is hot as is a yellow to to the relay. Why would there be two hot wires to the relay?
The way those diagrams are split up with the "yy" makes it hard to figure out.
And you can see that "zz" arrow leaving the main red junction. That "zz" wire is what powers the fuel pump relay coil on page 103 here.
But the red having power on it does nothing for the fuel pump relay, because the coil is not grounded, the computer selects when to ground the fuel pump relay coil through the tan/lightgreen which leaves on the "yy" and goes to page 62 here (this is terrible isn't it?)
You can see on page 62, the tan/lightgreen goes to the computer, and it also goes out to the test port plug so you can ground that wire manually to test the fuel pump system. I would think the Ford wiring harness you have would have the test port plugs, you need to get to know these well so you can pull the codes and do other things also.
Back to page 103 here
You are correct, power for the fuel pump comes from the yellow wire, goes through the relay, and goes out on a pink/black. It then goes through connector and changes to yellow. But these are early diagrams, this is the first or second year they came out with multi-port injection, and they start changing things right way. So your motorsport harness may do things a little differently, with basically the same results.
