cab shims
Old Apr 7, 2017 | 07:09 PM
jg513's Avatar
jg513
Old Apr 7, 2017 | 07:10 PM
jg513's Avatar
jg513
Old Apr 7, 2017 | 09:39 PM
petemcl's Avatar
petemcl
Looks good from the pix but you do need to get your rocker panels tacked in as they are critical to the structure. If you can do it with the doors closed and fitted it would be better.
Old Apr 8, 2017 | 06:20 PM
jg513's Avatar
jg513
Old Apr 8, 2017 | 06:21 PM
jg513's Avatar
jg513
Old Apr 8, 2017 | 06:22 PM
jg513's Avatar
jg513
Old Apr 8, 2017 | 07:06 PM
jg513's Avatar
jg513
Old Apr 13, 2017 | 11:59 AM
jg513's Avatar
jg513
Well i think i found out why the left side will not line up right. Years ago someone cut the trans mount allowing the frame to twist.pulling the cab back off to see if i can make a new trans crossmember and tweek the frame back to where it belongs just have to find out what the dim are.
Old Apr 13, 2017 | 12:17 PM
schoo's Avatar
schoo
and set the frame level and square, looks like the front RB bracket took a hit sometime maybe check that out also
Old Apr 17, 2017 | 08:00 PM
schoo's Avatar
schoo
Bumping this for more help
Old Apr 17, 2017 | 08:27 PM
schoo's Avatar
schoo
So jg have you studied your frame is it square and level
Old Apr 17, 2017 | 09:09 PM
Don T's Avatar
Don T
Hello jg513; we have to remember that these trucks were not built with quality in mind, get them out the door cheap was the idea. I chased my cab, front clip and hood positions around in circles for many hours to try and get the best alignment I could, there is no perfect. The pics attached show the left and right cowl-cab connections on my truck(factory origional) and somebody at the plant had to grab a drill to get the front clip to fit on. This is not your suppliers fault or yours, it is the nature of the beast. Go for door alignment first and shim or whatever to get the rest to work.
Old Apr 18, 2017 | 07:08 PM
  #28
jg513's Avatar
jg513
yes checked it out and had to modify trans mount to straighten up frame
Old Apr 18, 2017 | 07:11 PM
  #29
jg513's Avatar
jg513
thanks for the pic and info Don T i also have been going around in circles trying to get things to line up perfect
Old Apr 18, 2017 | 07:29 PM
  #30
schoo's Avatar
schoo
What measurements do you need?
66with352
Feb 28, 2018 02:33 PM
bjmayberry2
Aug 13, 2017 07:48 AM
armyaviation
Apr 8, 2017 06:47 PM
newguy399
19
Oct 26, 2016 06:16 PM
My First Ford
1961 - 1963 F100 Unibody
Apr 5, 2010 11:45 PM
