Brake Lines
Old Dec 29, 2014 | 11:15 PM
Vadis's Avatar
Vadis
Brake Lines
Getting ready to run completely new brake lines from front to back on my build and was looking into possible upgrades.
I've already grabbed some 9th Gen fuel and brake line frame clips that hold the brake lines out from the frame to prevent the lines from sitting in any built up dirt/snow/etc. but I still want to prevent the lines themselves from rusting away. On my current DD lines in high build up areas last at best a year
Stainless steel would be nice but from what I've read there's the possibility of leaks at the fittings since it's such a hard metal the flare doesn't seal properly.
So I went looking for something else and came across the Nickle-Copper alloy lines.
25' of 3/16 for $30 + stainless steel fittings for $30 on Amazon should do front to back with some extra for wiggle room.
Anyone has used the stuff?
Old Dec 30, 2014 | 07:12 AM
tjc transport's Avatar
tjc transport
i ain't rite
that is all i have used for the past 10 or so years.
i used to have to replace the steel lines on my 88 every other year.
the alloy lines on it now have been on the truck for close to 10 years now.
Old Dec 30, 2014 | 08:39 AM
exranger06's Avatar
exranger06
I replaced just about every brake line on my Bronco with the nickel-copper alloy stuff. Not only will it never rust, but it's super easy to bend and flare. I won't use anything else.
Old Dec 30, 2014 | 04:50 PM
Diesel_Brad's Avatar
Diesel_Brad
Another vote for the copper/nickle alloy.
really nice to work with and they LAST
Old Dec 30, 2014 | 08:15 PM
Vadis's Avatar
Vadis
Glad to hear this stuff is worth it, thanks for the reply guys
Old Dec 31, 2014 | 10:26 AM
'89F2urd's Avatar
'89F2urd
I helped put stainless lines on my buddys crew cab f3...they were pricey (pre bent) but they went together fine. I haven't heard anything bad about them, but then again im not really paying attention to brake line complaints either.
cant beat the price of the nickel copper though, and it seems to last.
Old Dec 31, 2014 | 05:17 PM
Vadis's Avatar
Vadis
Pre bent lines would be nice but the cost of getting them up here would be pushing $250+.
Those lines are probably fine as far as no leaks go as the shop probably runs a wicked flaring tool as opposed to the average Joe's cheapy tool.
I just put my order in for the tubing. Having a hell of a time finding some stainless steel tube nuts though. I was looking at a couple kits from Jegs but it was damn near $100
Amazon and eBay is from Jegs so those won't help. Any suggestions for where else to get them or an alternative?
Old Dec 31, 2014 | 05:34 PM
tjc transport
i ain't rite
i use the standard replacements from NAPA.
i don't need any of that fancy stainless stuff.
as far as flaring tool goes, i use an inline flair tool.
CalVan Tools (CAL164) In-Line Flaring Tool Fractional - Automotive Brake Adjusting Tools - Amazon.com CalVan Tools (CAL164) In-Line Flaring Tool Fractional - Automotive Brake Adjusting Tools - Amazon.com
i actually threw the old style bubble flair tool away after using the inline only one time.
Old Dec 31, 2014 | 05:45 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Screw Stainless line.
It sucks to work with.
Vote #4... or 5, for the copper nickel line.
It forms and takes flares easily.
It will outlast the rest of the truck.
Old Dec 31, 2014 | 07:20 PM
joey2fords's Avatar
joey2fords
... On my current DD lines in high build up areas last at best a year...
... i used to have to replace the steel lines on my 88 every other year...
you guys in the rust belt sure do face some challenges !
Old Jan 3, 2015 | 02:29 PM
Vadis's Avatar
Vadis
Yea, rust is brutal up here
Just curious but this kit that I link above, is that all the fittings I might need? I'm trying to find a cheaper source for them but with my truck being 25 miles away it's hard to get a total for all the fittings needed.
Old Jan 3, 2015 | 05:09 PM
Diesel_Brad
I don't think you will need the 1/2 or 9/16
IIRC on 3/4 and 1 tons you need..
(2) 7/16
(8) 3/8
Old Jan 3, 2015 | 05:38 PM
Vadis's Avatar
Vadis
Thanks Brad, the one place I've found sells them in packs of 10 so a few extras wouldn't be a bad thing.
Old Jan 3, 2015 | 05:54 PM
tjc transport
i ain't rite
if i remember correctly, the master cylinder has 2 large weird size nuts.
Old Jan 3, 2015 | 06:10 PM
Nothing Special's Avatar
Nothing Special
I've just reused those weird size fittings. Cut them off the old line and then slip them over the new before flaring.
