Transfer case
Old Apr 2, 2017 | 07:20 PM
green_95's Avatar
green_95
Transfer case
Bolting my 97 transfer case to my 93 zf tonight I have found that the linkage bar that connects the shifter to the transfer case is to long. I used the shorter manual bar. The e40d bar was atleast 8 inches long. Only wayI am going to be able to get it onto 4low is to grind some off the bracket. Anyone else run into this issue while doing a 5 speed swap?
Old Apr 2, 2017 | 08:30 PM
coreylasalle's Avatar
coreylasalle
The zf5 linkage is a lot shorter. It's like 3-4" iirc. I shortened mine, flattened the end in a vice, and redrilled the hole
Old Apr 3, 2017 | 02:39 AM
green_95's Avatar
green_95
I used the linkage off the manual donor truck. But still about a inch to long. Guess I will cut it down and drill a new hole for it.
Lazy_pig
25
Feb 5, 2015 11:00 PM
eriojas
1978 - 1996 Big Bronco
Feb 24, 2004 10:05 PM
baw289
Jan 13, 2004 08:51 PM
