Battery relocation
Old Apr 2, 2017 | 06:46 PM
mbpsycho's Avatar
mbpsycho
Battery relocation
I need to re located my battery in my 56 f100 from floor due to replacing bench seat with buckets need some ideas
Old Apr 3, 2017 | 11:32 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Here is an option I've seen online. Some of the old venders used to sell an inner fender with the battery box like this one, but I've not seen one for sale in years.
Old Apr 3, 2017 | 02:18 PM
The Outlaw's Avatar
The Outlaw
You could keep the stock location and go with a drop out battery box? Link
Old Apr 4, 2017 | 05:46 AM
mbpsycho's Avatar
mbpsycho
Thanks for the ideas .....2 great ones
Old Apr 4, 2017 | 07:02 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I've done two trucks...a 48 with 350 Chevy and a 49 with 302 Ford. In both instances I found ample room on the passenger side firewall for the battery...
Old Apr 4, 2017 | 06:19 PM
mbpsycho's Avatar
mbpsycho
Thanks Vern also considering that location
Old Apr 4, 2017 | 07:04 PM
48 Steel's Avatar
48 Steel
On my firewall a Odyssey PC 925 LMJ.
Old Apr 4, 2017 | 11:36 PM
burnettd01's Avatar
burnettd01
Battery location
How about in the rear portion of the right front fender.
This is how I did mine
Just a suggestion
Dan
Old May 26, 2017 | 04:01 PM
Pa&Nic51's Avatar
Pa&Nic51
I built a battery box into the passenger inner fender up high. plenty of room and a lot of empty space. Also close to started as i have ford 302 .
Old May 26, 2017 | 07:28 PM
Don Vito's Avatar
Don Vito
I used a polished stainless drop down box, I did not want the battery in the engine compartment..however I am still using a bench seat, I have the carpet cut and a removable piece of carpet to get access, the drop down box alone is ok, but if you need to jump it, it's a pain. If you don't mind it in engine compartment go with it mounted at the firewall. just my opinion
Don
Old May 26, 2017 | 10:31 PM
CharlieLed's Avatar
CharlieLed
Here is the drop down battery setup that I have in my 56:
Old May 26, 2017 | 10:36 PM
CharlieLed's Avatar
CharlieLed
Don
Many locations other than the battery to hook up jumpers...ground is simple, positive side can be picked up at starter relay, fuse block, back of alternator, etc. Small battery packs that are on the market now work great for jumping without the need for bulky cables.
Old May 26, 2017 | 10:57 PM
chad77's Avatar
chad77
Old May 27, 2017 | 07:15 AM
HILLBILLY BOB's Avatar
HILLBILLY BOB
I want to relocate my battery too.i like effie trucker's idea,i am also thinking about the firewall mount
Old May 27, 2017 | 08:50 AM
CharlieLed's Avatar
CharlieLed
Here is an inner fender mounted battery box that my buddy installed in his truck. The box is chrome so it is a little difficult to see in the picture but it looks real nice in the truck. I was always a bit concerned about placing that much weight in that location since the inner fender is not made for it...that said, it seems to work.
