1997 Ryder F 700
You think Ryder would go 429 on rentals? High probability it's a 370....
OP should post the VIN.
Also, do the standard trace --find something hot, and keep following the trail till you find the break. Juice to the module, juice to the coil, juice to the ignition switch?
Two different ignition modules are listed for your application.
5U2Z12A297B (replaced E8DZ12A297A) .. Remote Mounted TFI Ignition Module (Motorcraft DY1075).
F2PZ12A199AA .. Ignition Module-not TFI (Motorcraft DY683).
Both, according to the parts catalog are located on the left fender inner apron. The non TFI module is a (silver) rectangular box.
There were no 460 engines installed in anything larger than an F350. If there are 7 valve cover bolt holes per side, it's either a 370, or it's larger brother, the 429. Both look identical to a 460.
Post the VIN found on the Certification Label, or off the registration. Or if you want to keep it private, post just the 8th digit of the VIN which is the engine code.
Thanks for the responses. You all are right, it is a 429. I finally found a Ford service manual for it. It turns out the ignition module is mounted in a recess in the firewall. It bolts to a cover at the top of the firewall under the A/C line and only the connector is visible from the engine side. I feel better now that I found it, I beginning to think I was going blind.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
jtscottak
12-02-2014 10:13 AM
reamer
36
04-02-2014 08:19 PM
lars of colorado
12-08-2010 09:48 AM
