More power steering problems
Old Apr 2, 2017 | 05:09 PM
Ronnief150man's Avatar
Ronnief150man
1979 f150 4x4 6.6 liter engine I just hadon't my steering gear box rebuilt thru Auto Zone. Once we put it on, the new power steering pump magically didn't work. What would cause a good working, brand new, power steering pump go bad? It was only unhooked for 3vweeks.
Old Apr 2, 2017 | 10:37 PM
BLK79's Avatar
BLK79
Probably just has air in the system. Been awhile, but if I remember correctly the way to purge air is to jack up front end and work the steering back and forth lock to lock with engine off.
Old Apr 3, 2017 | 01:02 AM
meangreen92's Avatar
meangreen92
Someone on here went through this recently, and cracked open a line or something to ease the bleeding process, and finally got it working properly.
Old Apr 3, 2017 | 03:42 AM
Ronnief150man
We just turned the wheels back and forth but didn't jack up front end. Drove it down the road and back. After getting back home removed cap off reservoir and let it idles. There was no movement in fluid at all. It was at top of neck.
Old Apr 9, 2017 | 07:00 PM
Ronnief150man
Replaced power steering pump
Just wanted to update, I replaced power steering pump that was under warranty. It worked perfectly today. Thanks for replies.
ManfredVonRichtofen
27
Jan 15, 2012 10:08 PM
hotweekend
Jan 13, 2011 04:39 PM
squash04
Nov 22, 2009 01:14 PM
Andy_Bracy
Jun 10, 2007 10:10 PM
bryyce62
Nov 14, 2005 04:44 AM
