I'm new here but I just tore everything off my 53 F-100 yesterday so it's all pretty fresh in my mind. The first hole you showed is where the vacuum line went to the wipers and the second hole is a spot weld on mine. There is a matching spot weld on the driver side as well. It looks like someone may have drilled it out for some reason.
Thanks brochacho!!! Welcome to the board!! Do you still have the cowl weatherstripping on? Where the hood touches the cab?? I was thinking it was a screw hole for that.. can you post a pic of that if you still have it? Now that I think about it, that piece might go on the next level up...
The weatherstrip between the hood and the cowl is unfortunately missing from my truck but you are correct, it does install on the next level up. I have a series of "studs" across the cowl where that connects. If it helps it seems that spot weld is pretty deep on mine and almost looks like a hole but it doesn't go all the way through. I would think it would be ok to weld it up. I'm just getting ready to send mine off to the media blaster so I may be able to take some pictures of it when it gets back in a week or two.
