H4 headlight conversion
Old Apr 2, 2017 | 11:11 AM
edzakory's Avatar
edzakory
Has anyone converted their headlights (I have a ’56) to a Tri-Bar/H4 configuration or something similar?
I have a few questions:
Does the headlight (Tri-Bar) lens shell fit the grill and how is it maintained in place?
I assume you eliminate the old headlight cages. How do you adjust the beam?
Do you drill through the air deflector panel dimple to install the H4 bulb into the Tr- Bar lens shell?
Thanks.
Old Apr 2, 2017 | 03:07 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
The tri-bar is inside the headlamp, you just install it like the factory headlight, nothing changes not even the plug with an H4 bulb.
cdtech
Jun 24, 2008 10:33 PM
SteelHorse08
2004 - 2008 F150
May 21, 2008 03:44 PM
VatoLoco
Aftermarket Products
20
Mar 31, 2005 10:12 AM
