transmission floor cover?
we are on the home stretch of a restoration on a 1950 F1. We welded in a new floor and we got a new transmission cover. It's been so long since we took the truck apart we can't remember what the correct fasteners are to hold the cover down. What fastener should we use? I'm thinking number 10 self tapping panhead screws. There was no shifter boot on the truck. So I think the proper way to install the boot is ,boot on top of the foam on the transmission. Then the floor pan and finally cutting a hole in the floor mat to fit around the shifting boot. Anyone have any advice. Dale
I'm working on my transmission cover too. I purchased mine from classic haulers, and it came with pan head screws. My biggest hole saw blade was 4 inches, and I was hoping it could make a large enough opening. I realized that a 4 inch hole was a bit smaller than the original hole, but it still seemed bigger than the diameter needed for the shifter. In the end, 4 inches wasn't quite big enough. I have a 5 inch blade ordered. Good luck with your project. It's nice to be on the home stretch.
Thank's for the replies. I will head up town and see what they have. I think I will go with the pinhead screws because of the lower profile. We used a fly cutter to cut the hole in the pan. I think the dimension was 4 5/8 inch. Now I need to come up with a metal ring for around the gas pedal boot. We have three trucks in the yard and not one has the old boot or metal ring.
Not to hijack the OP's thread but if you've already cut the hole and it is too small, consider this. Scribe a line where you want the hole to extend. Drill small holes as close together as practical along this newly scribed line. Use vice grips and break the pieces of metal out along the line. Clean the rough edge of the cut out with a file.
Another way would be with a jigsaw.
I suspect you would have problems cutting a five inch hole over a four inch hole with a hole saw.
Edit: I used oversize sheet metal screws to attach the cover in my last two trucks.
I have a couple of O/S screws in my cover too, I think the assembly line guys weren't real careful about lining up the holes before gunning the screws in.
:. . . if you've already cut the hole and it is too small, consider this. Scribe a line where you want the hole to extend. Drill small holes as close together as practical along this newly scribed line. Use vice grips and break the pieces of metal out along the line. Clean the rough edge of the cut out with a file.
Aaron81
16
03-17-2019 07:07 AM
paulpatter
07-28-2007 11:45 PM
fordxxx
12-01-2005 07:34 PM
