Adaptive Steering question
Old Apr 2, 2017 | 10:15 AM
Kromer's Avatar
Kromer
I have it or so it says on the window sicker
How do you tell if its working, or when is it supposed to be working. I can't tell or notice anything which may also be the point i guess?
Old Apr 2, 2017 | 10:36 AM
Boilermaker374's Avatar
Boilermaker374
I can't tell with mine either other than it only takes about 1 1/2 turns to full lock position turning at slow speed.
Old Apr 2, 2017 | 12:30 PM
screwy's Avatar
screwy
That's exactly the point, it should be seamless. If you want to see what things are like without it I think you can pull the fuse for it.
Old Apr 2, 2017 | 12:42 PM
Odad's Avatar
Odad
The only time I really notice it is when backing up to a trailer. When I get off line approaching the trailer the steering recovers much quicker.
Old Apr 2, 2017 | 12:52 PM
DISLTom's Avatar
DISLTom
I think it helps make the truck more maneuverable. Makes it easy peasy to parallel park the giant thing!
Old Apr 2, 2017 | 01:21 PM
Sleepyguy's Avatar
Sleepyguy
PATENTED ADAPTIVE STEERING TECHNOLOGY HAS FORD COMPETITORS SPINNING THEIR WHEELS
Class-exclusive adaptive steering technology improves steering efficiency and steering effort – making all-new Ford F-Series Super Duty pickup and Ford Edge SUV easier to steer at all speeds
Based on driver input and vehicle speed, technology changes the steering gear ratio to provide optimal vehicle response for different operating conditions
System improves highway comfort and low-speed maneuverability by increasing and decreasing the steering ratio up to 30 percent; for Super Duty, it further improves driver comfort and confidence for towing or hauling heavy loads with tow/haul mode engaged
https://media.ford.com/content/fordm...echnology.html
Send free beers to the old guy on the patio at cactus club looking at all the young ladies.
Old Apr 2, 2017 | 01:57 PM
2009kr's Avatar
2009kr
4 turns lock to lock on my F450 with adaptive steering. Maybe folks without it can share their lock to lock count as well.
Old Apr 2, 2017 | 02:38 PM
reseehc_99's Avatar
reseehc_99
So that's a total of 3 turns lock to lock for the 250/350 with adaptive steering and 4 turns for the 450. I imagine the 450 with the wide track front end would require extra driver imput as the front wheels turn more giving it a tighter turning radius. I agree, it would be interesting to see what the non adaptive steering equalivient would be.
Old Apr 2, 2017 | 06:23 PM
Onebadamx's Avatar
Onebadamx
2014 PSD 350 Lariat SRW 4 Turns
Old Apr 2, 2017 | 11:02 PM
klassic's Avatar
klassic
Yep..1 1/2 turns on the button for me.
Old Apr 2, 2017 | 11:15 PM
K2500Z71's Avatar
K2500Z71
I was looking at the patent and pictures of the components trying to figure out exactly how this works. It looks like the steering wheel is attached to a motor assembly inside the steering column which is in turn connected to the steering shaft. The steering wheel serves as an input signal to the system and an algorithm determines how much the motor spins the steering shaft. Pretty slick. If that's true, does it mean that there isn't an actual mechanical connection between the steering wheel and the steering box any more?
Rockinfigs
Dec 7, 2018 04:51 PM
shelbysam
Apr 7, 2018 10:16 PM
18CCLBKR
Mar 16, 2018 07:50 AM
jm-bc
Mar 7, 2017 09:45 AM
socal_f250
Aug 2, 2008 03:38 AM
