wobble at high speed 2000 E150 Conversion
Old Apr 2, 2017 | 08:22 AM
Greg2000K's Avatar
Greg2000K
Ok so i put some Used 265 75 15 discovery copper MT tire on the rear of my e150 conversion van runs good in town, i went on the hwy and about 70-75 feel wobble but the steering wheel does not shake, so i get home and after reading lots of stuff, i get the tires balanced, no differance, so i lower the air pressure from 41 to 35 psi and that cures the problem, just dont want to be driving at 75-80 mph and have a rear tire blow out, but now thinking maybe not good idea putting those on the rear. As my front tires 235 75 15 are 41 lbs, thinking maybe if i can put 16 inch rims and tire all around to give a little bit of lift but with what i reading or understanding will the 16 rims fit or cause any other issues
Old Apr 2, 2017 | 10:07 AM
jimbomitch's Avatar
jimbomitch
I think it's the tires, nothing to do with the size, especially since you mentioned used.
Old Apr 2, 2017 | 10:18 AM
Conanski's Avatar
Conanski
There is no need to inflate any tire to max pressure unless the vehicle is at max load.
Old Apr 2, 2017 | 05:36 PM
CWR032's Avatar
CWR032
You might have a tire out of round. Lift one at a time and spin it, watch the surface of the tread to see if it goes up and down. Balancing doesn't fix that.
Old Apr 3, 2017 | 02:42 PM
vettex2's Avatar
vettex2
Please define wobble?
James Doty
31
Nov 6, 2018 09:08 AM
hwybee22
Aug 20, 2016 09:10 PM
Mudslinger21
May 16, 2009 09:47 PM
Boo_Daddy
Feb 24, 2009 07:53 PM
notn
Apr 8, 2006 07:36 AM
