Lack of power with vacuum advance
I have a 1984 f150 2wd 3.55
motor known:
was said to be rebuilt
302 86 HO roller motor
.040 over
E6 heads ( I know.. I know)
plugs gaped at .40
Fitech EFI
Duraspark distributor 14 initial 10L setting (20 mech) vacuum settings - 0° @ 4.5" Hg, 11.5° @ 8" Hg, 20° @ 12.5" Hg.
dual plane intake
Cranking compression 154 cold
Unknown:
cam ( guessing stock)
Compression im going with 9.3-4 ( running online calculators guessing stock parts were used I get 10.3:1 with a dynamic compression of 7.8)
Here is the issue
14 inital 20 mech no vacuum advance 1st will break traction on 2nd will too if wet or dusty at part throttle..
Hook up the vacuum advance and it feels like I have my brakes partialy engaged. It lacks power at part throttle and wot.
What could be the issue?
Thanks
motor known:
.040 over
plugs gaped at .40
Fitech EFI
dual plane intake
Unknown:
Here is the issue
Thanks
Does your advance pod on the distributor have two ports ? If so the front port is advance, the rear port is retard. Might also have too much initial with a stock cam at 14*. Also where on the carb are you plugging the vacuum into ? Should be a port above the throttle blades.
2. Where should I drop the initial?
3. I have it in the manifold vacuum port
Full manifold vacuum gives you full advance soon as you fire it up. Hook it up to a port (what carb ?) above the throttle blades, that's where it's supposed to go with a single port pod. Try setting the initial at 10* BTC also. All the Ford distributors since the late 60's had a dual port vacuum pod. Vacuum was directed from full manifold thru a temp controlled switch on or just before the T-Stat to either advance or retard.
I think I found the issue.. The truck was not warmed up and the efi puts in more fuel when cold.. I tested the vacuum advance when warm the other day. Cold the motor revs a little higher needs more throttle without the advance hooked up.. Cold with it hooked up the rpms stay down and it pulls. Warm it lacks a little power with both ways... I think I have to play with the pump shot and fuel delivery as it is running lean and the plugs are a tad hot. Thanks all.
It is an aftermarket EFI.. It has a handheld that you can change parameters...It is almost like the fast efi.. Holley efi system. You can change the wot, part, throttle, cranking , and idle fuel. You can also change the Air fuel Ratio targets. After driving a while it learns and adjusts
jav409
01-29-2005 06:16 PM
DeathMobile
53
05-17-2003 10:15 AM
