Vacuum Advance
Old Jun 24, 1999 | 11:57 PM
Sam Benham's Avatar
Sam Benham
Vacuum Advance
Would a 70 390 in an F100 have a timed vacuum advance or a full vacuum advance. I can't seem to get it to run right using the timed port on the carb, but it seems to run ok (no miss) when I use the manifold vacuum port. The distributor is stock for that year and motor. I have replaced everything in the ignition system and plugged the vacuum advance hose in the other port out of desperation. I rebuilt it myself and there are no emissions junk on it.
Sam
Old Jun 25, 1999 | 08:02 AM
slik's Avatar
slik
Vacuum Advance
I was told or given advice by a Ford mechanic that the Fords like to run off the manifold vacuum rather than the timed port. I've run mine off the manifold and it runs fine. It will especially idle better in city type driving. You do, however, lose the vacuum advance at WOT since the manifold vacuum drops to near zero in WOT.
Steve
Old Jun 26, 1999 | 02:56 PM
fordmando's Avatar
fordmando
Vacuum Advance
The same would apply with timed vacuum, it is just higher on the carb, under full throttle the ported vac advance should not be advancing the timing either, the mechanical advance should be doing the trick.
Vac advance is there to improve idle quality.
Old Jun 26, 1999 | 07:03 PM
rick's Avatar
rick
Vacuum Advance
Old Mar 14, 2007 | 12:09 AM
stormy750's Avatar
stormy750
I have a 1967 F100 with a 1978 351M powertrain. Since I replaced the advance unit (mine too was seized around the distributor main shaft), I've found that it advances too far upon acceleration. I tried two ports on the 2-bbl carb. and both end up with the same results.
Is there another lower-vaccuum place I can try/
Old Mar 14, 2007 | 12:43 AM
Mil1ion's Avatar
Mil1ion
Answering 7 1/2 year old posts will cause you to buy a round of beer for FTE 500 people
See my emissions album for a vacuum diagram for your engine.
The VA hose runs directly to the heated vauum switch first before it gets to the ported vacuum tube..
Old Mar 14, 2007 | 02:12 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Sam
Try direct vacuum first, because this will give you extra vacuum advance at idle, keeping your spark plugs cleaner over time; however, some motors tend to idle too rough or too fast hooked up direct, in which case, you should run ported vacuum.
http://www.performancedistributors.com/forddui.htm</O
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Superred2
Dec 15, 2010 11:43 AM
montana_highboy
88
Jun 24, 2008 09:37 AM
heavyd86
Jan 12, 2008 12:54 PM
PaulzF150
Apr 26, 2004 01:11 PM
kking1977
Apr 26, 2003 04:31 AM
