Sponsored by: Real Truck
Wheels and weight
Old Mar 31, 2017 | 10:35 AM
Moosetrucker's Avatar
Moosetrucker
Wheels and weight
Im looking to get new wheels for my 2011 F 250 SD 6.7 Diesel. Crew cab. There are 20 inch rims on it now and I would like to stay with 20inch rims. After looking at some wheels/rims I noticed they have a max weight rating. I was unable to find any good answers about what weight rating I should be looking for in a wheel/rim. I will be towing about 10K-16K pounds. The tire size I have now is 295/65 20. Any help or place I can educate myself on the topic would be appreciated.
Old Mar 31, 2017 | 10:57 AM
speakerfritz's Avatar
speakerfritz
your tires have the load rating on them
your axle max's are on your body sticker
the manual also has this info.
Old Mar 31, 2017 | 11:27 AM
Moosetrucker
Yes the tires do have the load rating. I am asking about the wheel/rim weight rating and how you determine what you need and how to tell if you are getting the right ones.
Thank you for responding
Old Mar 31, 2017 | 12:19 PM
FractureCritical's Avatar
FractureCritical
consider downsizing your wheels. The cost delta on 20" tires is significant compared smaller wheel diameter tires
Old Mar 31, 2017 | 12:34 PM
Ron94150's Avatar
Ron94150
Your rear gvwr is 6340lbs. You want wheels, and tires that will at least match that. I bought 18" wheels with a 3500 lbs rating, giving me 7000lbs total on the rear. You should have no trouble finding wheels in a 20" that will work. Larger wheels usually have a higher rating, it's the physics of a circle.
Old Mar 31, 2017 | 01:12 PM
Moosetrucker
Ron9
Thank you for the explanation. I was thinking that is how it worked but I wanted to get a clear answer. I have found many rims in a 20that will work.
Thanks again
heavyiron
Apr 19, 2021 02:11 PM
Miles Rittenberg
Jan 7, 2018 07:27 PM
pweng1
Jun 7, 2017 09:23 AM
BDalton
Nov 15, 2008 09:01 PM
Nicks91Explorer
Jul 21, 2004 05:04 PM
