Manually Shifting a C4?
Old Mar 30, 2017 | 10:23 AM
Old Coyote's Avatar
Old Coyote
I have a line on a 66 F100 I want to drive a few miles from where it is now to home. It runs fine but won't shift. The guys says the C4 in it is from a '73 Cougar. His dad owned it so he doesn't know a lot about the history. It's got plenty of fluid. I'm guessing it's a mod valve or vacuum problem, but can't really work on it where it is. Could I drive it without doing damage by manually shifting through the D,2,1 gears? I've never done this with an automatic.
Old Mar 30, 2017 | 11:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What size is the engine? C4's were installed with 240/300 I-6's. The only V8 used in 1965/66's was the 352, the only A/T was MX Cruise-O-Matic.
Old Mar 30, 2017 | 11:07 AM
Old Coyote's Avatar
Old Coyote
It's a 300/6. It's not the original engine.
Old Mar 30, 2017 | 11:44 AM
TA455HO's Avatar
TA455HO
Lead Gopher
You should be fine manually shifting the C4. If that caused damage they wouldn't have given the ability to shift manually.
Go for it!
Chad
Old Mar 31, 2017 | 10:37 AM
RacerJames's Avatar
RacerJames
I currently have a small block C-6 in my '64 behind a 351W. It won't shift automatically, and I have too many other things to work on to worry about that. So, I shift it manually, and have been doing so for five years (about 15,000 miles) with no noticeable problems.
Old Mar 31, 2017 | 02:54 PM
Old Coyote's Avatar
Old Coyote
Thanks guys. I'm going to get her tomorrow morning. Woo hoo!
Old Apr 1, 2017 | 07:42 AM
User 71024's Avatar
User 71024
I think the c4 ( taxing my feeble mind here),has a centifical shifter that can stick when not used, not sure if it will manually shift if it is stuck. You wont hurt the tranny shifting manually or even driving in low gear, but you can hurt the engine if it wont shift up. How far are you driving?
SSStang
25
May 29, 2018 08:59 AM
Alabama Style
Apr 5, 2017 01:04 PM
CMax1981
Jun 23, 2015 12:38 PM
Syntheglass
Aug 11, 2004 08:22 PM
