Does this ecu/pcm look bad?
Old Mar 29, 2017 | 07:21 PM
ZachE150's Avatar
ZachE150
Everything else looks good on this board but the white yellowish gunk on the end
Old Mar 29, 2017 | 08:28 PM
jimbomitch's Avatar
jimbomitch
Dialectic grease?
Old Mar 29, 2017 | 09:04 PM
NICKSAN's Avatar
NICKSAN
The main thing you want to look for are leaking capacitors. There are 3 of them that are a common problem on computers from F-150, E series vans and some other 90 models.
If your not familiar with electronic components they are called electrolytic capacitors and they look like this:
electrolytic capacitor : CUFCC Infomation
Here is a link to a thread here on FTE that discusses the issue:
https://www.ford-trucks.com/forums/1...e-problem.html
Theres also a you very helpful tube video that shows how to replace the capacitors.
I fixed mine a couple years ago but A few days ago I had to buy a remanufactured unit. It was about $140 with a $60 core charge from orielly`s
Have not installed it yet.
Old Mar 29, 2017 | 10:07 PM
Tim Hodgson's Avatar
Tim Hodgson
Just a comment from the peanut gallery here. Is that yellow crusty? If so it may be dielectric grease.
NEVER EVER put dielectric grease on a 12v electric plug and especially never ever on a 5v signal plug. It kills the signal.
Old Mar 29, 2017 | 10:46 PM
ZachE150's Avatar
ZachE150
JUst bought it. Having idle problems and codes thrown all about ECT, ATI, MAF and was wondering if the ECU had something to do with it. You think this could be the cause?
Old Mar 29, 2017 | 11:25 PM
Tim Hodgson
ZachE150: A couple of thoughts. Your rig will be a good rig for you, but all these rigs are getting old and the electrics are getting older too. And some of the previous accepted practices regarding dielectric grease have proven to be wrong. See my thoughts here:
https://www.ford-trucks.com/forums/1...l#post16563403
Also, it is said that mechanical problems are easy to find and hard/slow to fix. While electrical problems are hard to diagnose and fast to fix. You need to just accept that as fact.
It is also said that mechanics look to the component, while electricians look at the wiring. You need to get that mindset.
On rigs of our age, wiring fails at the plug interface.
Now here is the deal, on this forum the electrical issues are all over. If it is a truck it may be in the truck forum. If it is a Bronco it may be in the Bronco forum. Your PCM (Powertrain Control Module) is in the van forum. If it is perceived to be an engine problem, it may be in an engine forum. Look through all of them.
https://www.ford-trucks.com/forums/1...es-galore.html
Here is my current 5.8L thread in the Misc. Electrical Systems/Wiring forum:
https://www.ford-trucks.com/forums/1...51-eec-iv.html
And there are only a handful of people on this forum (and at a shop for that matter) that really have the deep knowledge necessary to help. And I am not one of them.
If you want to keep your van as your pony, start here and commit yourself to learning how it works.
Home
There is simply no substitute for learning and then employing a systematic methodical diagnostic approach.
Often things are more simple than you think. I had a miss caused by crossing spark plug wires (replace with Ford 9mm Racing wires and wire holders). I had a pulsing idle surge from 750 to 1000 rpm caused by the Air Conditioning in defrost mode calling for an increased idle rpm because Freon was low or the AC was otherwise defective.
Finally, your post is ok because it asks a pinpoint question. But for the real gurus here to help you, you need to put the info about your rig make model year engine transmission in your signature and then create a new thread with the Symptom in the title. And if you don't pull and list your trouble codes, none of the real gurus here will waste their time trying to help you.
Now here's the good news. The people here are truly Brothers. You do your part and they will go out of their way to help you.
Read, learn and keep posting.
thrifty
1947 and Older Ford Trucks
Jul 15, 2019 10:43 PM
wb6anp
Oct 16, 2017 06:44 PM
northerndave
36
Oct 24, 2016 08:43 PM
redfire42
26
Mar 10, 2010 04:06 PM
glruff
Missouri Chapter
Oct 5, 2007 11:11 AM
