Leveling a 250
Old Mar 29, 2017 | 10:10 AM
KIDkiser's Avatar
KIDkiser
Leveling a 250
i know this has been discussed numerous times,but I can't find it anywhere. I'm going to level my truck and I know I need 4 inch 350 blocks but what about the front?
Old Mar 29, 2017 | 10:22 AM
navistarnut's Avatar
navistarnut
Leaf springs or coils up front?
Old Mar 29, 2017 | 10:34 AM
KIDkiser's Avatar
KIDkiser
Oh I forgot it's coils truck is an 06
Old Mar 29, 2017 | 11:38 AM
ATS Junior's Avatar
ATS Junior
SPONSOR
You can either go with a spacer of some kind or an actual leveling coil.
Old Mar 29, 2017 | 11:48 AM
KIDkiser's Avatar
KIDkiser
1.5 inches or 2?
Old Mar 29, 2017 | 12:37 PM
silverbullet6oh's Avatar
silverbullet6oh
If your looking to "level" the truck, usually a front coil spacer or new leveling coil spring is installed. The rear of the truck doesn't need to be lifted.
Most go with a 2" or 2.5" lift in the front, whether that be from a coil spacer or coil spring.
I didn't like the slight sag look, so I decided to also put a 4" rear block in the back.
Now it has a little rake in the truck.
F350 rear blocks are 3.5".
- Preston
Old Mar 29, 2017 | 01:03 PM
KIDkiser's Avatar
KIDkiser
Did you go with a 2 or 2.5? Cause the measurements I'm getting there's only 1.5 difference in mine now.
Old Mar 29, 2017 | 01:46 PM
snorindad's Avatar
snorindad
This is the leveling kit I went with for my 2006 F-350. Not hard to install. Although id did ball joints and the track bar ball joint and seals all at the same time.
Ford Leveling System
Old Mar 29, 2017 | 03:02 PM
silverbullet6oh
I have 2.5" front coils, with 4" rear blocks.
Before the 4" rear blocks, my front was higher than my rear by 3/4".
Now with my setup, my rear is about 1.25" higher in the rear. And thats without my airbags inflated.
Rusty_S
13
Aug 8, 2016 07:40 PM
LemonHeadTyler
May 28, 2012 09:04 PM
HarleyFXDL
Nov 30, 2009 08:16 AM
91s10350
Feb 22, 2007 07:41 PM
kgorman
Jun 1, 2005 12:14 PM
