Sponsored by: Real Truck
turbo squeak
Old Mar 29, 2017 | 08:22 AM
opy's Avatar
opy
turbo squeak
While engine breaking I started hearing a squeal under the hood , when I started accelerating it became a little louder , I pulled over and when I rev it up it gets louder and has a little rattle sound, sounds like it coming from the turbo
Old Mar 29, 2017 | 10:38 AM
r2millers's Avatar
r2millers
That doesn't sound good. The turbo bearings are sensitive to heat and require proper lubrication.
Always good to let the turbo spool down before shutting the engine off to help prevent possible loss of lubrication.
See if you can pull the CAC and reach in to spin the vanes to feel any binding. Not sure how easy it is get there unobstructed?
Old Mar 29, 2017 | 10:55 AM
opy's Avatar
opy
It sounds worse now after cooling off a bit. I just took it to the shop I think it is the smaller turbo on the drivers side, that is where the noise is coming from
Old Mar 29, 2017 | 11:05 AM
r2millers's Avatar
r2millers
Didn't know it was a 6.4l. They are known to fail after the back two cylinders dump DEF/fuel down those cylinders to regenerate the particulate filter, etc.
Good luck.
Old Mar 29, 2017 | 05:39 PM
sxrfun's Avatar
sxrfun
May just be broken exhaust manifold bolts or cracked up pipe......check exhaust manifold at rear on drivers side.
Old Apr 2, 2017 | 02:45 PM
opy's Avatar
opy
That is exactly right it was a cracked up pipe and bad sensor!
SLUF681
May 30, 2011 10:06 PM
MoyockPowerstroke
Jul 28, 2009 07:19 AM
jdap
Jan 25, 2008 05:25 AM
abealex
Jan 16, 2007 09:00 PM
richallen
Jul 23, 2005 06:41 AM
