Stealth or Stryker
Old Mar 28, 2017 | 06:10 PM
Strokin-A-2010's Avatar
Strokin-A-2010
Stealth or Stryker
Been reading about both these modules and supposedly they are untraceable. But the Stryker is nearly double the price of the stealth. Anyone run either of these products on their 6.7
Old Mar 28, 2017 | 07:06 PM
Rutcutter's Avatar
Rutcutter
I think they both do the same thing if not mistaken just a different label... Let me know what your findings are..
Old Mar 28, 2017 | 07:29 PM
17 Oaks's Avatar
17 Oaks
Due to the code and parameters they change, I see no way that even if it is restored back to what it was at point of install, there is still a history that shows the changes that occurred over time.
That said it may well be that someone looking at it cannot tell if it was changed by ABC or Stealth, but, but the changes are there and it would be up to a VERY knowledgable tech to ask you what programmer you used. Then you just play dumb and say I loaned it to my brother in law and who knows what he did.
IF well written and well implemented on install and uninstall it could well take a solid software engineer to dig it out, but I assure you, we can (or in my case I could, but long since retired)
Old Mar 28, 2017 | 07:43 PM
Strokin-A-2010
I believe they both do they same thing as well. Just curious why the Stryker is nearly double the price.
Old Mar 29, 2017 | 08:23 AM
bikerman5345's Avatar
bikerman5345
There have been some reviews on a 2017 facebook page about these modules. The stryker is the one laying down the most power and mpg increase from users. One guy had both and compared them back to back and noticed better improvements with stryker.
One thing to consider is the stryker has seen some issues with lag with aftermarket intakes installed. They are thinking since it increases the power so much the truck is limiting itself in the factory program. These do not flash your ecu or change any factory settings. It just controls your injectors for a more precise tunning so they will not leave a trace. Once you unplug it, the factory controls are back in place.
Im not affiliated with either of these and havent used them personally but i have been researching them extensively as i also want to add something that wont void the warranty on the expensive engines and emissions parts.
Old Mar 29, 2017 | 08:38 AM
Oz97tj's Avatar
Oz97tj
I have a Stealth. My fuel economy went up a bit but not much. Overall power, even when set on the strongest setting, doesn't seem like a huge increase but the truck is far more responsive so I like that. I have an intake coming that is supposed to be here tomorrow so we will see how they play together.
The Stryker has one more plug, that I don't remember what is is, but it controls two parameters vs just the injectors of the Stealth. That's likely why it's making a bit more power.
loudfords
Ontario Chapter
Apr 18, 2007 11:18 AM
jasongt06
Car/truck Buying Advice
Apr 1, 2007 10:33 AM
1956MarkII
18
Apr 2, 2006 05:58 PM
1BDTrk
Nov 3, 2004 03:48 PM
maximnole
Apr 26, 2004 08:02 PM
