Hood flex with wind gust
Old Mar 27, 2017 | 09:35 PM
silver_pilate's Avatar
silver_pilate
Just thought I would post an observation. We've had plenty of wind out here on the south plains this spring and winter. Lots of days with 40+ sustained gusting to 50-60. I was driving up an overpass at around 65mph into the teeth of the wind one of those days and caught a gust right on the chin of the truck. I figure the combined wind speed was probably topping 120 for that instant. My hood lifted at the driver's corner and slightly rippled/flexed across the front driver's half right before my eyes. It didn't create any permanent change or damage, and it was only an instant right when the gust hit, but I don't recall ever seeing a steel hood doing that. I almost thought the hood wasn't fully latched, it lifted that much, but checking it when I stopped showed that it was.
Nothing I'm concerned about that much, but if you're doing 75 on a two lane and meet a semi coming the other way on a windy day, don't be surprised if your hood flexes a bit. Anybody else notice this so far?
--Nathan
Old Mar 27, 2017 | 09:40 PM
lkbrow1's Avatar
lkbrow1
i noticed it too doing 65 on a windy day
Old Mar 27, 2017 | 09:43 PM
The Ace of Spades's Avatar
The Ace of Spades
Sure have, and it gets your attention when it happens.
Old Mar 27, 2017 | 09:46 PM
silver_pilate
It sure does! Really surprised me that it wasn't permanently bent after seeing how much it moves with the center securely latched. Hope I don't hit that "perfect storm" combination of speed and wind/gust and prove my fear someday.
--Nathan
Old Mar 28, 2017 | 07:26 PM
FOUNTAIN 1's Avatar
FOUNTAIN 1
Yes they sure do. Fenders move by the lights a lot also. Not secured for chit. Not to mention the sides of the truck look like a flag blowing in the wind. Can't ford build a strait panel. Christ everything looks dented n wavy. Thing that catch my eye. I'm pretty picky. I guess. I just think a door n fender should be straight not looked dented or wavy. Also
Old Mar 28, 2017 | 09:26 PM
Chadmokc's Avatar
Chadmokc
Yes my '17 does it but in its defense my '11 Powerstroke also did it as well.
Old Mar 28, 2017 | 09:38 PM
RJC2's Avatar
RJC2
As my 2002 and 2017 sit side by side in the garage, I pushed on the body panels. The metal panels are stiffer than the Al-Li panels. This probably explains why hail doesn't damage the Al-Li panels as easily. They flex, absorbing some of the energy of he hail stones.
I too don't like the wavy body panels. I noticed it when the 2015 F150s came out.
Old Mar 29, 2017 | 02:06 PM
Sleepyguy's Avatar
Sleepyguy
The nature of the metal comes into play even though we really don't know the full alloy fact it is aluminum based means it should flex better and retain metal memory better then steel counter part.
I was also surprised to see the hood flex when clearing snow from it.
Old Mar 29, 2017 | 02:16 PM
archerseven's Avatar
archerseven
Have also noticed it, but didn't think too much of it, other than it was more pronounced than I expected. My friend's Mazda 3 does the same thing, willing to bet it has an aluminum hood.
Old Mar 29, 2017 | 04:12 PM
frogracer's Avatar
frogracer
I have seen hood flex on my 2009 and 2013 F150's and my new 2017 F250. Not sure there is much need for concern.
Old Mar 30, 2017 | 10:00 PM
jb-hunter's Avatar
jb-hunter
Yep, buddy thought my hood was not latched... said nope, it does it every time a big truck with bad aerodynamics meets me on a two lane.
Old Mar 20, 2018 | 10:01 AM
deanr1066's Avatar
deanr1066
Hood flex
--Nathan
I too have seen this on my 2017 F-250. I live in a very windy area where winds of 70-80 mph are not uncommon. When I meet a semi on a 2 lane highway while driving 60-70 mph it happens frequently. I have also seen it happen on high terrain and while driving highway speeds but usually on turns when meeting larger vehicles. I question over time if the integrity of the aluminum will be compromised due to this? Will this weaken the aluminum and cause damage/failure or even worse the hood to lift? Can't say i'm completely comfortable seeing this so often
mrmag00
Dec 6, 2019 12:03 PM
Onus
Oct 4, 2011 08:14 PM
46yblock
1947 and Older Ford Trucks
22
May 25, 2010 08:08 AM
Strokerin
Mar 16, 2007 07:00 PM
kameronth
1978 - 1996 Big Bronco
Aug 24, 2004 01:42 PM
